Originally Posted By: FutureDoc
Source?
Search the SAE paper archives. The majority of wear material (and wear causing material) is iron-based. The bypass filter most likely has a 50% limit of around 2-4 micron, the magnet (with an open pole to the fluid) will have no such limit.
Prove to me that more magnets trap more material than the OEM equipment and a proper tranny fluid change routine.
It's not much different than increasing filtration area of a typical media-filter. As area increases you can hold more material, but in the pan you also affect more of the fluid. Since the OEM magnet is very limited in size and is a bit on the weak-side, adding to that side of the equation is very beneficial. Again, the magnets will also be pulling iron out of the fluid 24hrs-a-day whereas the filters are only effective while the engine is running.
From a transmission longevity standpoint, more magnets don't matter, better fluid change regiments, changing the filer and the occasional drop the the pan is all that is needed.
It does if the fluid stays cleaner longer. In fact, if you can keep your ISO cleanliness levels low enough you may never really need to change the fluid again.
Again, I'm not saying you need to drop the pan, clean it (and the OEM magnet) and go whole-hog on a killer magnet field. Installing a Magnefine will give you much of the same benefit (minus the 24hr action) in an easy-to-apply package.
