Originally Posted By: mattd
Originally Posted By: ctechbob
If the engine rocks in the engine bay it wouldn't be the engine that's seized you wouldn't think. In order to rock the starter would have to be torquing against something in the driveline, if the engine is completely seized there should be no rocking.
Just a theory.
This. I would look at the transmission before the engine. A seized engine will only make a “click” sound and no engine movement. With no warning or noise I find it hard to believe the engine is the issue.
ASE L1????????
Have you ever seen a car with a seized engine???
I have seen car too many and have never seen the engine rock side to side. One solid click from the starter. If the crank doesn’t move the engine won’t rock back and forth. If it is indeed seized I would sure like to know what happened as this would be the first time in 13 years I would have heard about an engine that “rocks” when the starter engages. But hey, you see something new every day I suppose.
If it is indeed seized, as stated I would guess timing chain failure but they usually make noise on these engines before failing.
OP, did the engine move in the opposite direction?
He needs to manually Bar the engine over with a ratchet/breaker bar & remove all 8 spark plugs.
Yes...I have seen seized/hydrolocked engines move around with starter torque.
Just a theory.
ASE L1????????
