Originally Posted By: LeakySeals
Originally Posted By: Nickdfresh
Originally Posted By: Ram01
Clean the throttle. Body also
+1, spray out the air-intake...
How do I do that?
Take off the rubber connector between the air filter and the air intake manifold. Use the throttle to open the butterfly (when the car is off) and spray away using a good air intake cleaner spray like CRC. I usually see tons of gunk and carbon deposits come out and it noticeably improves performance. At 66K, it might not make a huge difference though. I'd have a good fuel injector cleaner in the tank while doing this, or at least Top Tier gas.
When you reattach everything and start the car, keep in mind it is going to possibly stall or run rough for a bit...
How do I do that?
