Unfortunately, even if you use DW1 and change it every OCI, that might still not be enough to prevent transmission problems
The V6 Hondas are known for bad transmissions.
Maxlife should be as good as anything else for that car. Some people are afraid of ATF/CVT combo fluids (which Maxlife is now), but it's probably safer to use on a regular automatic than on a CVT.
Otherwise, any synthetic ATF that's not an ATF/CVT combo is good.
Valvoline has an Import Multi Vehicle ATF. It's thicker like Z1 rather than DW1, but that's ok because DW1 didn't exist at the time. If you still desire DW1, there is the Extended Protection ATF.
Castrol used to make a great full synthetic ATF, but it was replaced by the ATF/CVT combo.
Havoline Synthetic ATF
The best price on full synthetic ATF that actually says DW1 on it seems to be Triax
If you're willing to spend the money, Redline D6 is also good and probably the best you can get.
Lubegard's complete ATF might be worth considering. Lubegard is more known for their additives, but they also make complete fluids.
DW1 came out in 2011
Here is where I read that 2008 was the year Honda turned its back to their older, deficient transmission designs.
The universally maligned Z-1 became DW-1.
DW-1 was the only juice I'd use on the neighbor's Accord.
