My 2007 Kohler Courage 17HP engine has spark, turns over well, but will not start. No luck using starting fluid either. Valves are set at .005 intake and .007 exhaust. I saw where the top of the combustion stroke should have the flywheel magnet in line with the ignition module (coil?) but mine is about 30 degrees before it lines up but the piston is at TDC.
I have a rod inserted to know when the piston is at the top of it's stroke and the valve rocker arms are loose. As I spin the motor to line up the magnet with the ignition module one of the valves does begin to open. Is this a problem not having the module lined up with the magnet at TDC?
I have a .010 air gap so as mentioned am getting good spark. If not a problem, could the automatic compression release be defective and not allowing compression to build for the power stroke?
Any thoughts why it won't start even with spark and starting fluid and all safety switches are operating correctly since I do have spark?
