Have they rerun that sample to ensure it's accurate?
That’s where the conversation is going with him so far. I have no problem with 2k-2.5k mile changes, that’s a little under a year for me. Just good to know what my changes need to be.
Sticking to 2k ish intervals now, trying the 15w-40 HPL next because why not! May eventually return to the Amsoil. Thanks for everyone’s input.Amsoil 10w40 with the fuel dilution was still in grade, double the TBN and a better additive package in my opinion. Granted the Amsoil was 900 miles less on the OCI, however my thought is to run the Amsoil again for the same length OCI as the HPL. I try to keep my OCI'S the same length so it can be relatively consistent following the performance in terms of staying in grade, TBN etc. The wear element is what it is but leaves a signature with respect to how well it stays in grade, remaining TBN etc.
I could do a straight weight in the summer, not all year though. Sounds like HPL may try tweaking the blend for me once they verify OAI’s results. I changed the oil though so will have to wait until the next fill.Yeah, I'd have expected the HPL to held up better, considering how much it costs.
See if HPL can whip you up some no-VII 40.
Or, run Valvoline VR1 SAE40, if it doesn't bother you that it's a non-synthetic, non-MC specific oil. You'll never have to worry about shear. My bike loves the stuff. Currently $40/6 qts on Bezos Express.
Guess my Lubegard Biotech isn't so bad.HPL loads most of their oils with moly.
.Guess my Lubegard Biotech isn't so bad.![]()
Heck no..
Do you have a 250 Ninja?
That thread discussing the VR1 40 grade was very informative. Until freezing point, it ran neck and neck with a 20w50 for being suitable in terms of flow.Yeah, I'd have expected the HPL to held up better, considering how much it costs.
Like it’s a bad thingHeck no.
It’s just the trifecta: high loads, high revs, small sump capacity =oil killer.If you have two different, unmodified bikes set to run off of JASO spec, I would be concerned if they had a wildly different propensity to shear. The horsepower and torque of the motor or rw don't tell the whole story as much as the transmission gear loads do. Is the spec all that generous that an engineer can really rack up the load? As always, it is of course all within the life framing of warranty and reputation costs.
I believe the sump size is what hastens your permanent shearing, tbn depletion, and oxidation (if you determine any.) I don't think theres a leg to stand on that you are certain it has significantly higher loads, but that's by-and-by from the former.It’s just the trifecta: high loads, high revs, small sump capacity =oil killer.
Absolutely, sump size sucks. There is a leg to stand on in the load department because, again, I keep it under heavy load, wide open, 6th gear pinned and I weigh 200lbs+.I believe the sump size is what hastens your permanent shearing, tbn depletion, and oxidation (if you determine any.) I don't think theres a leg to stand on that you are certain it has significantly higher loads, but that's by-and-by from the former.
.Absolutely, sump size sucks. There is a leg to stand on in the load department because, again, I keep it under heavy load, wide open, 6th gear pinned and I weigh 200lbs+.
That's great usage. My point is that with respect to the transmission, that's not going to amount to any more shearing than any other bike.Absolutely, sump size sucks. There is a leg to stand on in the load department because, again, I keep it under heavy load, wide open, 6th gear pinned and I weigh 200lbs+.
I like it well enough, I just use it to cruise back roads around where I live. I have other larger bikes, but this is perfect for what I use it for.Different engines. Yours is a single cylinder, while the Ninja 250R is a parallel twin; it holds nearly 2 qts with filter.
The KLX300 looks like a great bike. How do you like yours?
Looks like this engine and my right hand tear up oil! Bit surprised, however, now I know what OCI should be so that's good. Have 5gals of HPL 15w-40 HDEO sitting here so may experiment with that later on. Enjoy!
Take good care of the bike. Get a good price for it. You are ready for a bigger bike. Ain't no replacement for displacement. Stay safe!No, the other one on there is Amsoil Metric 10w40. I'm with you, a bit surprised that HPL didn't hold it's own, and nothing changed in riding habits or the bike between Amsoil and the HPL. Now, to give the oil some credit, I ask for everything this motor has everytime I ride it. I weigh 220lbs and I usually ride at 9-13k RPM so I am not easy on the bike. Still, I was hoping for at least 4k OCI.
