2007 ACEA oil spec.
I like the depiction of the older CCMC Gx migration path. Many older BMWs etc that called for the older CCMC specs.
I think if I remember correctly, my 96 BMW would call for an A5 based on the current path.
A5 a step up?
Compare carefully to A1.
At this point in my understanding it is a minor step up.
Seems differences are more diesel oriented.
HondaMan, as you probably know BMW has there own LL-98, LL-01, LL-04 spec's (long life). This is another story.
Quote:
A5 a step up?
The primary difference between A1 and A5 is that A5 is an extended drain spec.
