dnewton3
Staff member
I see some common ground, perhaps, in our views!
I am learning to release my preconcieved notions of sump size and fitler size. I long ago learned to release my prejudices of base stock and OCI duration.
My 2010 Fusion has a 5 qrt sump and a tiny filter. And yet, the UOAs are outstanding in regard to wear and contamination, with an OEM 7.5k mile OCI. After warranty is over, I could concievably see 10k miles doable, safely, on dino oil and that tiny filter.
Long, long ago, in the infancy of my lube-world exposure, I knew only of the OEM recommendations. Then, I was introduced to synthetics. AHA! What miracle fluid is this? Why does everyone not use these every 3k miles? Then, reality set in.
I got a job at Ford where I had to run a large maintennce program for a 2 million square foot facility, including production machines and building equipment. Gearboxes and bearings were my life for several years. I started using UOAs and understanding the relationship of lube/filter performance to ROIs.
Now, I know "better". I don't judge any situation on the surface; I let the data talk and I try to listen.
