1996 MB E300D - M1 Truck & SUV 5w-30 - 7960 mi
JHZR2
Staff member
New Jersey
This is a UOA from my father's 1996 MB E300D. 3L I6 non-turbo diesel engine. Makes about 137hp. Used just about entirely for highway commuting.
He bought it last april or may with about 140k. We changed it over to M1 truck and SUV from whatever the PO's dealer (always dealer serviced) used (maybe M1 0w-40?) We ran it for a short OCI, and now are extending it out. Manuals suggest 7500 mi OCIs.
Looks good to me. I think next time we will do 10k. I think we could do 15k OCIs, but I think Fe may get too high. 10k might be a nice OCI for this engine. Comments???
code:
Sample Date 2/27/2005 9/11/2004
Unit Age 157087m 149127m
Time on Fluid 7960m 3867m
Time on Filter 7960m 3867m
Fluid Maint. Changed Changed
Filter Maint. Changed Changed
Fluid Mobil1 Truck&SUV 5w-40 Mobil1 Truck&SUV 5w-40
Iron (Fe) 27 13
Chromium (Cr) 1.4 1
Nickel (Ni) 0.7 0.1
Titanium (Ti) 0.2 0.1
Silver (Ag) 0 0
Aluminum (Al) 3.5 2.6
Lead (Pb) 1.1 0
Copper (Cu) 0.9 0.6
Tin (Sn) 1.2 0
Silicon (Si) 6.3 5.8
Sodium (Na) 1.1 1.5
Potassium (K) 0 1.4
Boron (B) 44 36
Barium (Ba) 0 2.2
Molybdenum (Mo) 2 2.4
Magnesium (Mg) 426 347
Calcium (Ca) 2264 2029
Phosphorus (P) 1185 973
Zinc (Zn) 1228 1073
Sulfur (S) 3651 3417
Cadmium (Cd) 0 0
Manganese (Mn) 0.3 0.2
Vanadium (V) 0 0
Soot(%) 0.3 0.2
Oxidation(PA) 80 70
Nitratrion(PA) 40 25
Sulfation(PA) 0 0
ZDDP -0.06 0
TBN 10 10.2
Kv@100°C 13.6 13.2
White Metal NONE NONE
Babbitt NONE NONE
Precipitate NONE NONE
Silt NONE NONE
Debris NONE NONE
Dirt NONE NONE
Appearance NORML NORML
Odor NORML NORML
H2O(Emul) NEG NEG
H2O(Free) NEG NEG
[ March 15, 2005, 10:31 PM: Message edited by: JHZR2 ]
Soot is very low (0.3%) and TBN is still 10 at 8000. Iron at 27ppm is still pretty low. Try 10k OCI next time and compare. I bet you could go 15k OCI if your driving habits don't change.
I'd change the oil filter @ 7500 miles and sample/change the next batch of oil @ 15,000 miles.
This is a very clean burning older MB w/ low soot levels and a good ring seal. TBN retention shouldn't be an issue at all with this type of highway driving ....
I'd try to keep the Fe < 100 ppm at change out....
TS
Does anyone have comments about his high oxidation and nitration numbers? I figured these would be low with all highway driving.
This lab probably uses an allowable limit of 200 units for oxidation and nitration. So you're @ 40% and 20% of the allowable limit, expressed as a percentage. The stable viscosity would indicate that oxidation isn't a factor in this analysis....
