Friend owns a 1994 Civic LX 1.6L Master Cylinder with ABS.
While driving for at least one block and coming up to a stop light, the brake pedal sinks and seems to slow the car down just a bit.
After quickly releasing the brake pedal and re-applying pressure to the brake pedal, the car stops without any problems.
To me this sounds like a classic Master Cylinder (MS) problem.
My friend also told me that he thinks that he might of poured power steering fluid into the brake reservoir a few years ago. He's not sure.
He added that this brake symptom has only been happening for a few days.
I told him that there could be air bubbles in the system and that we should try bleeding the brake fluid first.
If we get no air bubbles coming out of the bleed screw(s), we can then proceed to replace the Master Cylinder.
Any other advice is greatly appreciated.
