Originally Posted by Trav
Originally Posted by clinebarger
Originally Posted by Astro14
It's been a long time since I've done a GM pinion seal, but I recall some of them having a non-reusable crush sleeve that set the pinion bearing pre-load...
Was this one of those?
Or is a torque value that sets pre-load?
Either way, it was quiet before, so your work is what changed it, and I suspect, as you do, that the pre-load is off...and I suspect that this is similar to the 10 bolt on my old Trans-Am that needed a new crush sleeve when doing the seal...
The crush sleeve "can" be reusable, It all depends on IF it rebounds when preload is removed via loosening the pinion nut. If you get slack in the pinion bearings right away when loosening the pinion nut.....The crush sleeve is rebounding & still good enough to return to service.
If the light press on the front bearing & the sealant on the Yoke splines is enough to keep preload on the pinion bearings....The crush sleeve is DONE.
I don't like using crush sleeves at all, Just about EVERY GM corporate differential can be converted to a solid spacer....Then you use shims to set final pinion bearing preload.
GM used generic no-name bearings in a lot of differentials starting in the late 1980's into the nineties, Before that GM used a mix of Hyatt & Timken bearings which were very high quality. Warranty work went through the roof during this generic bearing phase, Then they started using Timken & Koyo with far better results.
If this differential is whining.....The pinion bearings are probably toast!
Yes, I forgot to list that in my post "check the bearings" if he drove it around they are probably damaged but its no big deal to swap them if the carrier is out.
I am interested in this spacer and shim, is there a kit for this? This will work with late model diffs found in pickups? I haven't worked on GM diffs at the dealer level since the early 80's so I missed the generic bearing failures it seems.
Think it's something like this
https://www.quickperformance.com/GM...n-Spacer-Adjustable-w-shims_p_21511.html
