Okay, this is the sable i post about when i talk about it.
I have the AX4N (the "Good" transmission for these cars) it takes 13.5 quarts of Mercon V, now i am unsure of when the transmission fluid was last changed, but i do know that i can empty the torque converter by disconnecting it from the trans cooler, and just let it idle out the fluid.
Now my question, should i drain the fluid out, it is dark colored and has a varnish smell, but passes a drip test on a paper towel, as it spreads out properly. Or should i just leave it as is due to the high milage. I do not intend to power flush the fluid out, or add any additives prior to it, if i do change the fluid it will be Mercon V, not Mercon/Dex, or mercon III, or any multi ATF.
Also, what brand of trans filter do you reccomend, i was thinking going to NAPA and getting it all there using my grandfathers AAA card and 3.5% sales tax (most stores are 7%)
