Originally Posted By: Virtus_Probi
Originally Posted By: Or
What is the real-world difference in cold start between comparable 5w30 and 10w30s when the ambient temp is around 30F/0C? I see lots of specs on visc. at much higher and lower numbers but can't find any practical information about what it means around there, which is "winter cold" in a substantial part of the US.
Shannow posted this a while back:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3891475/Re:_For_those_that_constantly_#Post3891475
You can see that straight SAE 30, at 30F (-1C) has the oil coming out the rockers at 3 seconds and full oil pressure in 6 seconds. A 10w30 shows the same 6 second full oil pressure at 9F (-17C) but a slightly longer 10 seconds for the rockers. A 5w-20 at a warmer 12F (-11C) shows the same 6 second full oil pressure time but a lower rocker flow time of 5 seconds, similar to the SAE 30 at 30F. This illustrates that generally, using a lubricant with the appropriate W rating for the anticipated ambient temperatures results in approximately the same amount of time required to reach full oil pressure.
I don't find this to be very useful because these temps are not really COLD.
That's cold enough for 90% of Calif... And that's ~30M people with cars.
10W-30 is nearly the ideal oil for much of the mixed fleet use in Calif. Truckee, Susanville and Mammoth could use a 0w30 in the winter. But thousands of skiers cars start just fine on 5W and 10W, even up there ...
