So, I have been tossing the idea of a 0w20 oil around a bit or LOT lately and my OCD is really kicking in. Options are M1 0w20, Synpower 0w20 or PP 0w20, possibly 0w20 EDGE. Driving is 90~ % highway and very little stop and go driving also
I have been using AMSOIL Signature Series 0W20 for the last 100,000 miles changing it once a year. I have 131000 on my 09 ford Edge now and good to go for another 130000.
Originally Posted By: 2015_PSD
Originally Posted By: car51
2015_PSD: you used just the M1 AFE correct for your tests/ UOA's?
No; the 17K run was M1 EP.
I'm planning to use M1 EP 0W20 with Fram Ultra in 2014 Accord for 2 OCI's. I would reset the first OLM and change oil&filter on second OLM.
Ok
I should have added this to the OP...I used AFE for the other runs and I have posted previously that I was not that impressed with EP versus AFE. The TAN was much higher with EP versus AFE (but not high enough to be overly concerned)--the AFE just seems to be all around good oil.
Yeah, just read they your UOA's. So which did you feel was the overall good oil? AFE or EP?
AFE. I just did not see the value in EP and I am certain that I ran it long enough to see if there was a difference between them. Of concern was the TAN reading between AFE and EP. Granted, nothing happened to the engine and I am sure it could have gone longer but 8.9 TAN (EP) versus 5.3 (AFE) with only a 2K mile difference was a little telling to me. The other part is **most times** EP costs more than AFE. My entire stash for my Explorer (save for the 1 OC of PUP) is AFE.
I have PP 0w20 in the sump now, im going to change it tomorrow with some more PP 0w20. My malibu likes it and its not consuming oil. I went to walmart and picked up some mobil1 AFE 0w20 for the following 2 O/C's and going to fill out my rebate forms. Got some acdelce pf64's on the way from rockauto so after rebates the next 2 oil changes are only $15 a piece.
Im trying out the PP 0w20 right now in my camry, but I got a ways to go still, another 10k before its time to change it out. With the 0w20 toyota brand oil the engine would consume a bit down to the low mark on the dipstick, but I'll see how it does with the PP oil.
Lots of good choices in this grade these days.
If I had to select one oil in this grade, I'd probably go with M1 AFE. As noted above, there's also a sweet rebate through May 31st.
I'm not sure what you hope to gain in using this grade over a 5W-20, particularly with 90% highway driving, but it certainly won't do any harm.
