Originally Posted By: Blue_Angel
Everything has to be read in context.
Certainly.
Here's a real life example of what oil viscosity can do at startup. I put TGMO 0W-20 in my '02 Corvette which has a hotter cam installed. Now when I say "cold start", keep that in Corvette context... it's a summer car and a 50-60F start is a cold start. Previously running M1 10w30 the car had a real lopey chop-chop idle for several minutes after starting. With 0W-20 in the engine almost all of the cold start drama is gone and it even idles noticeably smoother when hot, but the "massive" difference is when cold. Same engine starting at the same temperatures, much smoother idle.
That oil is known for its low viscosity at startup temps and I see that is at work here. There's no need to turn this into a TGMO thread (there are plenty of those), this is a viscosity thread. I would expect any oil that light to behave the same.
I must be numb. I started my Expedition in -30C (that's not a typo) in Quebec this past winter and aside from the power steering pump making noises that would make anybody cringe and the battery not being too keen on the endeavor it sounded and felt exactly like it always does. Oil in the pan was PU 5w30, which would have been 4,000cP, as that's the CCS value for that oil at that temperature.
I can go out and start it right now, with the same oil in the pan (I haven't even changed it yet! LOL!) and it will feel and sound the exact same (minus the power steering pump noise of course, LOL!)
Also, if we are citing cammed examples I had a TFS #1 in my H/C/I '87 Mustang GT. I ran it with 1.7's so it was about .530/.540 lift, but relatively mild duration (221/225) on a 112LSA. It had a decent lope to it. It sounded the exact same when it was cold or hot and whether I had 0w-20 or 5w-50 in the pan.
Do you have an H/V or H/V H/P pump in the 'vette? Something that would maybe make it "work" a bit more when cold? I was running the stock Ford pump, pan and pick-up.
Quote:
For those still not thinking along these lines, consider how smoothly your car idles with and without the AC running.
My cars all idle the same with the A/C on or off, LOL! You do notice the change in idle when the compressor engages, but that's just a blip/audible thing.
Quote:
Most small engine (four cylinder) cars develop a much rougher idle with the AC on, and most people can barely tell the difference in fuel economy with or without using AC. That compressor may put a bit more load on an engine than pumping thicker oil does, but the effect is the same.
Our Focus never did and the Subie doesn't?
I DO notice a fuel economy hit with the A/C though. And it is noticeable to me.
I will also repeat the most important part of something I was onto earlier:
If you don't drive a manual transmission and rev match your own shifts you're unlikely to notice anything!
Driving a slushbox isolates you so much from what the engine is doing there's no way I would
expect someone to feel an improvement. Some claim they have and I believe them, but the average shmoe driving an autobox car can't feel much of what the engine is doing to begin with, let alone be tuned in to subtle changes.
My Corvette is a different car with lighter oil, and that's going from a 30 to a 20. Rev-matching gears is so much quicker and requires less of a throttle input than before. I've owned this car since 2004 and have put over 100k miles on it in that time. The engine has never revved as freely as it does now.
I never could (feel a response/free rev difference between grades) with my Mustang (75mm BBK TB on it) and I certainly can't with the M5 but it has 8 TB's and is drive by wire and the grades used in the M5 have all been relatively close to each other (BMW 5w30, M1 0w-40, PU 5w-40). However the M5's I drove with 10w-60 in them didn't feel any less responsive.
I can also feel ABSOLUTELY NO POWER INCREASE AT ALL. Once you're pushing it hard it feels no different than it did with the 10w30 in it. If there was any OVERALL power gained by the switch to a lighter oil I'd need a dyno to tell... my butt sure can't.
At lighter loads when just loafing around and rowing through the gears, THAT'S where the car "feels" so much better. And as before, don't knock it unless you've tried it.
I'm not "knocking it" but I have certainly tried it and can't relate, LOL
If you're not going to try it then stop telling people who have that they're wrong! How the heck could you tell someone that brussel sprouts taste bad if you've never eaten one? Try one, you just might like it!
Well that sort of ties into my earlier point about not recommending people run oil grades thinner than what is specified by the OEM unless they are WELL aware of the potential consequences, particularly when under warranty. Your 'vette is long out of warranty and never spec'd xW-20 anything. But you've embarked upon that journey knowingly, just like CATERHAM does with his projects and that's fine. It is advocating that approach for others that I have issue with. I'd never want to be the guy responsible for recommending something to somebody that falls outside the range of what the OEM specified and then they lunch their engine. I'd feel like an absolute bag of fecal matter.
Some guy puts TGMO in his F-body based on all the cheerleading for the product on this site and takes it to Laguna Seca and then spins a rod bearing, windows the block and he's down an engine. Not saying that WILL happen, but it is certainly a possibility. Especially if he's not somebody with the proper gauges to track oil temp and pressure and even if he does, isn't used to watching them.
Or maybe a more realistic example would be an M3 (known for rod bearing issues) that spec's 10w-60 using TGMO on the track, LOL! It could happen! I am quite certain many people take the advice doled out on this site as the Gospel.
