0W-08 Engine oil
Fake news and alarmist nonsense
It was just some humor. The closest we got to testing 0W-4 was on the Lincoln Navigator BITOG thread, when the OP put 0W-5 oil into an engine speced for 5w30. After 1,000 miles, there were visible pieces of metal in the oil filter.
Lies and propaganda
2008 was the last sane year of the Toyota Corolla. That year's Corolla is speced only for 5w30 for all temperature ranges in the owners manual. In the owners manual and dashboard maintenance minder light, Toyota recommends 5,000 Mile / 6 month OCI (not 10,000 mile OCI). It uses screw on oil filters (not cartridges), normal tension piston rings (so no oil burning), bulletproof engine and transmissions that several forums say you can drive it 300k miles. I'm getting about 40 MPG on the highway.
I'm getting 40 MPG with 5w30 and normal tension piston rings in my 2008 Toyota Corolla.
I'm not understanding the need by Toyota to go to 0W-8, on these new vehicles. Could a car speced for 0W-8 reach 300,000 miles on the original engine? Time will tell.
My friends has an original owner 2000 Pontiac Sunfire with the original engine and 440,000 miles on it. His secret is mid quality 5w30 and 5,000 mile oil changes. Also on the original catalytic converter and it doesn't burn oil.
someone posted foreign owner manual, this is your answer…. Car is not “speced” to use single viscosity, its a range….
In the US based 2008 Toyota Corolla owners manual, 5w30 is the only viscosity listed for all temperature ranges. It mentions 10w30 can be used if 5w30 is not available, but on the next oil change you must go back to 5w30.
Toyota/Lexus been writing this language forever, my lexus 2012 es350 has the same language. In 2013 es350 went to 0w-20, and they did ZERO changes to any of the internal engine parts 2GR-FE engine.
The only reason they put this language is because they realize 0w-8 might be difficult to find in some areas
Yeah and going to 0w-20 back in 2013 Toyota got to post the mpg numbers a little bit higher for that car, then that raised their cafe number slightly.
Don't hate the players, hate the game.
we have a fleet company that gets all their vehicles serviced at my work, all the cars they use are toyotas new and old including ones that call for 0w-08 0W-16etc, the company requests 5w30syn in all their vehicles. some of these vehicles have well over 100k miles all running on 5w30 with 0 issues.
