I'm greedy, but any of the 12 TBN Ams. formulations should be good for a 15,000 mile OCl in this application. I would stick with HT/HS viscosity of at least 3.5 Cp @ 150C, due to the chain drive.
Originally Posted By: daschrier1
Originally Posted By: 98LSC32V
I don't see why a naturally aspirated 2.5 liter needs a 40 weight oil to run properly. If it was the turbo motor I would stick with the 40 weight though...
It's what VW recommends.
I know the older 2.0L will burn a ton of oil if you don't use the 5w40 stuff. My gf has a 2004 jetta gl and her oil lasts a lot longer since I've switched over to the castrol 5w40.
My wifes 97 Jetta 2.0L has used GTX 5W30 and Syntec 0W30...there was no buring oil. Her 2.0L seems to run better with 0W30.
