Hi everyone, its my first post here. Great site with lots good info.
I started to notice a bearing noise from the transmission when cold and clutch engaged, but goes away when clutch is pressed in. I think it the input shaft bearing but dealers deny it as it is still under warrenty. Its nothing that hurts operation, just a noise at idle. Anyway, I got the trans fluid analyzed when I changed it at 60000mi, which is the recomended intervel. Here is the data. The aluminum reads high according to the lab, they classified it as abnormal, but not severe:
Lab: Wear Check Canada, Mississauga Ontario
Car: 2005 Acura TSX 6spd manual
Fluid: Factory Honda MTF 60000mi/3 years (never changed previously)
A bit of info about the driving. This car is driven moderately hard, but not excessive, maybe a 6-7 out of 10 average. I am easy on the transmission meaning no crazy downshifts and always rev-match when if i do. About 2/3 highway driving.
(All numbers in ppm)
silicon 34
potassium 0.6
water(%) dirt, debris, precipitate None
white metal light
babbit None
iron 147
nickel 1.4
chromium 2.2
titanium 0.1
copper 74
aluminum ***42
tin 4.9
lead 18
silver 0.2
boron 3.5
barium 16
calcium 2561
magnesium 800
molybdenum 1.9
sodium 8.7
phosphorus 1084
sulfer 4284
zinc 1167
visc@40C 35.1
The lab has aluminum catagorized as "abnormal" at 25ppm and "severe" at 75. So the reading is not severe but still above normal. What do you guys think, Could it be a bearing? Thanks for any feedback, much appreciated.
silicon 34
potassium 0.6
white metal light
babbit None
iron 147
nickel 1.4
chromium 2.2
titanium 0.1
copper 74
aluminum ***42
tin 4.9
lead 18
silver 0.2
boron 3.5
barium 16
calcium 2561
magnesium 800
molybdenum 1.9
sodium 8.7
phosphorus 1084
sulfer 4284
zinc 1167
visc@40C 35.1
