Hi folks! First post, I really enjoy reading this forum. I was hoping someone could recommend a good procedure for replacing the ATF in my 2002 Tundra. Some background: Currently has 135k on the clock, ATF fluid was only replaced once around 65-70k mile mark with the Toyota brand ATF. I believe Toyota specs Dex-III for my transmission. At this time I also cleaned with ARX.
Right now, I'm struggling with if I should get another flush on the transmission and replace the fluids with the Toyota fluid, or if I should just start replacing the fluid in the pan with Mobil-1 synthetic. (Or should I do both?)
I'd like to switch to synthetic ATF because I've had such good luck with M-1 10w30 @ 7500k OCI (Wix filters.) Not sure why I don't spend as much time worrying about my transmission as I do my engine.........
