Im driving a turbo lancer with limited engine bay space. I plan on changing to the biggest model of atf cooler ie the Hayden 679, but if i do that it has to be sandwhiched between the radiator and intercooler. A significant portion of the intercooler will be infront of the ATF cooler.
As such would the purpose of the atf cooler be defeated since heat would be transferred frm the ic to atf cooler? is the temp of ic less than that of the atf cooler and thus there will still be cooling of the atf fluid?
