Hello BITOGers. I've been lurker here, but now I got my second UOA form Blackstone and I am worried. German Castrol 0W30, ~5k miles. Previous UOA on Exxon dino 10W40.
Mixed driving, 60% highway, 40% commute 12 miles one way. Car always warmed up properly - under 3k rpm until oil temperature reaches 80-85 C.
I don't understand the high silicone content - I replaced air filter at the time oil was changed. Checked the filter and it's clean and installation appears fine (properly sealed intake tube to the filter box).
I took the sample while changing oil and perhaps I did not warm up it enough. Just to reach the working oil temperature.
Also I mistake I made was to not clean fumoto valve before dumping oil. However I didn't take the sample immediately, I let a quart or so to drain first.
I need to resample. Should I use a pump like the one blackstone sells, or it's okay to drain some oil (when hot) via fumoto? I guess the pump is a safer bet.
I'd appreciate your help!
[image]http://s150.photobucket.com/albums/s108/wujek1976/[/image]
