1987 Toro Rebuild Project
by Torox
05/20/13 05:16 PM
Tires Plus Coupon
by renegade_987
05/20/13 05:01 PM
Cement knowledge ?
by OtisBlkR1
05/20/13 04:54 PM
atf for 1990 volvo 74
by DesertTundra
05/20/13 03:44 PM
mobil1 vtwin 20 /50 in harley drive train.
by larryn
05/20/13 03:27 PM
VML vs PHM
by Ga129
05/20/13 03:02 PM
How to sell my near-new tires?
by 97tbird
05/20/13 02:52 PM
3m furnace filters 60% off home depot.-Monday only
by Rand
05/20/13 02:38 PM
Oil Smells Burnt
by sgvaibhav
05/20/13 02:35 PM
2005 Malibu 3.5 Liter V-6
by 2James1
05/20/13 02:26 PM
Whats this part called?
by KenO
05/20/13 02:00 PM
Which Octane for '06 Sienna 3MZ- FE
by mshu7
05/20/13 01:44 PM
oledad86, alxhastngs, CJS, magicsammy, jhg7
45479 Registered Users
133 registered (1999nick, Amateur, aquariuscsm, Artem, 97tbird, alan_mac, 12 invisible), 1617 Guests and 252 Spiders online.
45477 Members
64 Forums
193680 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 3 of 6 < 1 2 3 4 5 6 >
#810292 - 01/15/07 04:13 PM Re: Need to get my beater car to stop smoking. [Re: skate1968]
dx92beater Offline
Loc: va
Quote:
dx92beater,
I drive a dx91 beater which i actually like very much (91 honda civic DX). And i've been going through a similar problem.
I just want to add two additional comments to what everyone else has said.
Thick oil reduces smoking in the summer months. But i have found that it can actually make it WORSE in the winter! One cold morning i started my car and got a ton of smoke! I thought that i must have tore a ring/gasket or something major. But actually the motor honey had made the oil so thick that it wasn't circulating properly. So switching to thinner oil actually made my beater smoke less at start up. I'm not sure exactly how cold it gets in your part of Virginia, but maybe something to consider.
Now, while using moderately thick oil i make sure to warm it up first so it thins and circulates before I drive. (Reving a cold engine is especially bad in our cases)
Also, instead of using 15w-50 in the winter. I'm now considering 3 quarts inexpensive rotella 5w40 with one quart of 15w-50.
A second long range plan. With my car, the 4rth generation civic, a low-miles jdm engine is somewhat of an affordable option (single overhead cam). I'm not sure if this is the case with your make and model.
good luck!
Thanks for this. I had no idea that a thicker oil could cause more smoke in winter. Maybe I'll give a thinner oil a shot? The JDM engines are cheap, but the mechanics around here want PLENTY to get one in. Then I'd have an ugly car that I put thousands into. My other car, a 94 Infiniti G20, cost me $900 and it is in awesome shape. It's an auto though. I use that one when I go out with the family. I just enjoy the philosophy of getting 42 mpg with this protege and since I already have it, it's hard to get rid of.
93 Escort GT 35 mpg at 67 mph sub 8 second 0-60 and 4.10 final drive! D6 in manual Tranny.
#810293 - 01/15/07 04:15 PM Re: Need to get my beater car to stop smoking. [Re: Lonnie]
dx92beater Offline
Loc: va
Quote:
Try a dose of Auto-RX, follow instructions. If you are still getting smoke in the morning and on slow down from a run on the freeway but it still runs good you might want to replace the valve seals. They can be replaced without removing the head. It's a common cure for old Civic's. Do not go thicker than 20w-50 and add nothing to the oil, no honey, no STP, no fix-it-in-a-bottle, nothing. I put myself through college buying smokers and fixing them, except I did not have something like Auto-RX. I used hugh doses of Marvel Mystry Oil and did valve seals in my garage. It just takes an air compressor and a few tools, but if it's not what you do find an independent mechanic that knows your brand of car.
Could you please expand on this Auto RX stuff? Where can I get it? What color bottle? Is that supposed to stop valve stem seal smoking, or simply pinpoint that the problem is bad valve stem seals?
Thanks
#810294 - 01/15/07 04:21 PM Re: Need to get my beater car to stop smoking. [Re: c502cid]
dx92beater Offline
Loc: va
Quote:
Beater cars are all over the place. I know, I own bunches of them. Easy solution? Sell it on craigslist for whatever you can get for it. Buy another beater on craigslist. Lots of good $1000 cars for sale. Lots of them. My latest, 1998 Ford Escort 5 speed for $800. Great gas mileage, ac blows cold. It needed a radiator, thats it.
I like what you are saying, but I want my next car to be nicer. I am guessing that I want to drive this one into the ground since it has new tires, a new gas tank, new brakes, thicker radiator, new thermostat, mx-3 recaro seats etc.
It does have some major things that are invariably going to go though (seems like original clutch, don't know the status of the timing belt on this non-interference engine).
Hope my approach isn't too non-sensical, lol.
#810295 - 01/15/07 04:22 PM Re: Need to get my beater car to stop smoking. [Re: Rand]
dx92beater Offline
Loc: va
Quote:
Thats a tough question but really you can do no wrong when
your car is on its last legs.
I'm not a fan of lucas OIL additive.
I would just use something like castrol HM 10w40
or maxlife 10w40
Maybe straight 30weight delo.
sounds like oil is leaking down after the engine is shut off
making it smoke like crazy on startup
(dont know if that makes sense)
Is one HM better for this than the other? That has been one of my biggest questions?
#810296 - 01/15/07 04:24 PM Re: Need to get my beater car to stop smoking. [Re: ekrampitzjr]
dx92beater Offline
Loc: va
Quote:
You could always try the notorious oil thickeners such as Motor Honey, Motor Medic, Motor Paramedic, Motor Mortician, etc., but after a point that's playing with fire, namely by clogging the oil intake. One quart every 1,000 miles should not nearly be enough to be seeing blue smoke all the time as you are.
The white smoke you remember from before concerns me. You haven't said. Are you sure you aren't losing coolant? My hunch is that you will have to get the head pulled to do a valve job (to replace the valve stem seals at least) and a head gasket job.
I am positive that I am not loosing coolant, not one drop. I have heard that burning oil CAN appear white, and I believe it to. No longer applies though since it now appears TRUE BLUE. Thanks
#810297 - 01/15/07 04:24 PM Re: Need to get my beater car to stop smoking. [Re: 55Test]
dx92beater Offline
Loc: va
Quote:
Get a used cylinder head from a junkyard. Toss a friend a case of beer and 50 bucks or so and have him/her change the head on a free weekend.
No pals. All dead, or moved on.
#810298 - 01/15/07 04:26 PM Re: Need to get my beater car to stop smoking. [Re: 427Z06]
dx92beater Offline
Loc: va
Quote:
Are you sure the oil isn't getting into the combustion chamber some other way other than the rings or the valve stem seals? Maybe it's being drawn into the manifold thru the PCV system? See if you can somehow get a look in the manifold. What did the plugs look like when you pulled them? Is all the smoke coming from the tailpipe? Or is some of it possibly leaking onto the exhaust system?
If your on a military base, most use to have auto hobby shops. Hunt down a copy of a shop manual, or goggle for the procedure, and see what it would take to replace the valve stem seals. With a $100 in parts and a weekend at the hobby shop, you might be able to replace with a little help from one of your buddies.
After HM 20w50, there's little else that can be done oil wise.
No buddies....all passed on.
All the smoke is coming from the tailpipe and I changed the PCV valve. Plugs are never wet with oil though. HMMMMMMM
#810299 - 01/15/07 04:28 PM Re: Need to get my beater car to stop smoking. [Re: ebaker]
dx92beater Offline
Loc: va
Quote:
Continue the 20w50 or thicker with walmart motor honey additive. Replace any oil fouled spark plugs with hotter ones. Check the PVC. Make sure the head is not sludged, blocking the oil return. Try idling a minute before shutdown. Park at the far end of the parking lot at work.
How can I tell if the head is sludged blocking the return?
Would this cause these symptoms? Is relief to that presumably regular oil changes etc?
#810300 - 01/15/07 04:31 PM Re: Need to get my beater car to stop smoking. [Re: Drew99GT]
dx92beater Offline
Loc: va
Quote:
Pennzoil 20w-50. Eventually, after a week or two, the wax will fill in around the valve stem seals and plug up the leaks. Problem solved. Then you can go into the candle bidness
On the other hand, if the seals are really old, cracked and messed up, you could run 85w-140 gear oil and it wouldn't help the situation that much.
I'd simply run a 20w-50 high mileage oil (seal conditioners), like Supertech, and hope for the best. It's a beater, your topping off a lot etc.; go at least 7500 before doing a full oil change. Heck, you could go 10,000 miles with ease, with a filter change half way through. Your doing a full oil change every 3,000 miles anyhow with a quart ever 1K, provided you keep it topped off. That wouldn't even be pushing it. Good luck.
So you are suggesting giving Pennzoil HM a shot? Any reason you have this brand in mind? hmmmmmmm...I have long thought about what you mentioned about...if the seals are shot and cracked.
Still, only 9 months ago or so, I got this thing to stop smoking enough to get by emissions. I can't remember how anymore though.
#810301 - 01/15/07 04:33 PM Re: Need to get my beater car to stop smoking. [Re: Triple_Se7en]
dx92beater Offline
Loc: va
Quote:
Next time buy a more trusted model like Corolla, Civic, Neon, Focus or Cavalier.
Agreed, but this was the only car available to me in my situation. Heck, my beater corolla blew its head gasket after owning it 4 months. I know its not the most common thing to hear, but it was just my luck.
#810302 - 01/15/07 04:34 PM Re: Need to get my beater car to stop smoking. [Re: m2200b]
dx92beater Offline
Loc: va
Quote:
Gas mileage tells you you are probably ok on compression but the cheapest look is to pull the plugs to look for oil soaked ones with bad compression or white ones that mean a cracked head with coolant leak. Do check the pcv and its hose qand grommet as you'll get more consumption if that system is bad and you tend to get more head carbon that leads to a lifted head gasket.
You can't run 30 delo in the winter period. I'd try the 10-40 HM like castrol and pennHM as they're close to 50 anyway and I wouldn't use a 20 weight in even a DC winter. I do think ARX will narrow down if its valve stem seals as it sounds as the ARX won't help that much but does cure alot of other abuse. If you have a head gasket cracked I'd be looking at used JDM motors as that motor is relatively cheap like the honda and tercel ones. You've already used too much solvent cleaners so I'd layoff those before you do effect the bearings.
I lost track of whether you smoke just on startup or off every traffic light?
Just at startup FYI. Thanks for the tips. So this ATX stuff won't help valve stem seals?
#810303 - 01/15/07 04:35 PM Re: Need to get my beater car to stop smoking. [Re: dx92beater]
dx92beater Offline
Loc: va
I meant ARX not ATX...I think, lol.
#810304 - 01/15/07 04:36 PM Re: Need to get my beater car to stop smoking. [Re: dx92beater]
dx92beater Offline
Loc: va
What about non-detergent oils? Could that help in this case?
I haven't heard anyone say anything about that. From what I see, they are super cheap at Walmart under the accel brand name.
#810305 - 01/15/07 04:36 PM Re: Need to get my beater car to stop smoking. [Re: dx92beater]
dx92beater Offline
Loc: va
....alrighty then... I'm done...
#810306 - 01/15/07 05:40 PM Re: Need to get my beater car to stop smoking. [Re: dx92beater]
jonny-b Offline
Loc: Norway
Why don't you buy a bisycle if maintaining your car is such a problem?
