Single cylinder versus twin
by mjoekingz28
34 minutes 41 seconds ago
Mobil Super Syn vs ...others
by Yup
Today at 12:45 AM
2016 WRX
by Silver02ex
Yesterday at 11:58 PM
Class Action Lawsuit Against Oil Filter Company?
by crazyoildude
Yesterday at 11:42 PM
PL10241 Cut Open
by Vegoose
Yesterday at 11:15 PM
Seems like common sense to me......
by Doog
Yesterday at 11:14 PM
Thinking of buying an old diesel Benz
by Diego3336
Yesterday at 10:46 PM
Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
Yesterday at 09:43 PM
2007 corolla oil pan steel or aluminum?
by Rolla07
Yesterday at 09:07 PM
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
Yesterday at 08:56 PM
Paint correction
by mjoekingz28
Yesterday at 08:55 PM
Filtertran Filter From My Vehicle 96K Miles
by oil_abuser
Yesterday at 08:53 PM
engus, Rob_Pol, Nick24w, SkipKaye, MikeHancho
56899 Registered Users
19 registered (dgunay, barnstormer, deoxy4, Jason8691, 4 invisible), 577 Guests and 189 Spiders online.
56899 Members
66 Forums
244580 Topics
#809684 - 01/13/07 07:01 AM Techron concentrate used as maintenance dose
virginoil Offline
Loc: western australia
Hi
I have not found any information for Techron Concentrate Fuel System Cleaner recommended to be used at each fill as a maintenance dose on a weekly basis.
If it was to be used weekly what's the correct dosage for the fuel treatment, 1 oz (30ml) per 45 litre tank ?
Current usage is about every 6 months (varies between 6000km to 7000km) just before the oil and filter change.
Incidently, is a weekly maintenance dosage better than a 6 month perodic system flush.
Your assistance is appreciated.
Thanks, Virginoil
#809685 - 01/13/07 08:32 AM Re: Techron concentrate used as maintenance dose [Re: virginoil]
psudaytona Offline
Loc: Pittsburgh,PA
I wouldn't bother with it using it like that. If you want a constant clean use Redline SI-1 at a dose of 1/4 or 1/2 bottle every other tank. Techron is good at cleaning but it seems to loose effectiveness when you only use tiny amounts.
If the only product you can secure is Techron, and if you really value a clean fuel system I would say run a bottle every 3 months. That should be more than enough to keep it in tip top condition.
1998 Crown Victoria Police Interceptor
4.6L V8
#809686 - 01/13/07 09:05 AM Re: Techron concentrate used as maintenance dose [Re: psudaytona]
Vilan Offline
Loc: Surrey, BC
http://www.chevron.ca/ProductsServices/Retail/FuelSystemCleaner.htm
"If you regularly use a high-quality gasoline such as Chevron, you probably don't need TechronŽ Concentrate."
That tells me that constant tiny amounts are indeed helpful.
If you don't use their gas and want to add Techron to other gas, they say this... (warning: math ahead!)
"Use every 5,000 kms to keep your entire fuel system clean.
Available in two sizes, 355ml bottle treats up to 45L and 590ml bottle treats larger tanks, up to 75L."
Virginoil has a 45 L tank so we'll dump in 355 ml every 5k km (3k miles). Say you get 20 mpg. That's 150 gallons, 600 L of gas in that time. If you added that bottle of Techron gradually over the whole time, that's just over 0.5 ml Techron per liter gas, so 22.5 ml per 45 L gas. So an ounce per tankful sounds just about right.
#809687 - 01/13/07 04:41 PM Re: Techron concentrate used as maintenance dose [Re: Vilan]
mckennaiii Offline
Loc: virginia
i use to use this but have switched to fp60 from lube control and like that much better. all three of my cars seem to have much more pep since using fp60.
#809688 - 01/14/07 11:56 PM Re: Techron concentrate used as maintenance dose [Re: mckennaiii]
RogerKlugerAus05 Offline
Loc: Victoria Australia
I use Redline S1-1 at the recommended dose at every tankful, the bottle is graduated so it is easy. Full bottle in the tank every 10k kms at the service.
Roger
#809689 - 01/15/07 02:56 PM Re: Techron concentrate used as maintenance dose [Re: RogerKlugerAus05]
virginoil Offline
Thank you for all your comments.
I will think I might try maintenance dose 0.5 ml per litre.
Virginoil
