The WIX for the 5.9 is rated @ 12-16 gpm ..as are most for that engine, or so I would reason. You can go to a XE
Part Number: 51607
UPC Number: 765809516076
Principal Application: Cummins 5.9L "B" Series Eng, Dodge PU w/Diesel Eng. (86-02), Various HD Equip. (For High Efficiency Fluted Version Use 57620XE).
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 6.987
Outer Diameter Top: 3.670
Outer Diameter Bottom: Closed
Thread Size: 1-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=17/27
Burst Pressure-PSI: 350
Max Flow Rate: 12-16 GPM
Nominal Micro Rating: 17
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.255
Part Number: 57620XE
UPC Number: 765809526204
Principal Application: Extra Efficiency Version Of 57620 - Has Fluted Can (can use in place of 51607)
All Applications
Service: Lube
Type: Full Flow
Media: Paper/Glass
Height: 7.000
Outer Diameter Top: 3.690
Thread Size: 1-16
Beta Ratio: 2/20=14/25
Burst Pressure-PSI: 378
Max Flow Rate: 12-15 GPM
Nominal Micro Rating: 14
Gasket Diameters
Attached 2.830 2.440 0.225
Part Number: 57620
UPC Number: 765809576209
Principal Application: Dodge Pickups w/ 5.9L Cummins Diesel, "B" Series Eng. (03-06) (Fluted Version Of 51607) (High Efficiency Fluted Version is 57620XE)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 6.945
Outer Diameter Top: 3.681
Thread Size: 1-16
Beta Ratio: 2/20=20/30
Nominal Micro Rating: 20
Gasket Diameters
Attached 2.835 2.461 0.170
But ..as long as you're not peaked in pressure ..they all look the same to the flow
