Thin oil, thick oil, synth or dino,
by Cruzingoose
02/13/16 11:25 PM
Compete today? Modernize your skills on own time
by spackard
02/13/16 11:23 PM
Castrol 0w30 leaving Advance Auto Parts
by bbhero
02/13/16 10:53 PM
Oil Change Marathon Today
by BlueOvalFitter
02/13/16 10:01 PM
Raybestos Advance Tech or Police Rotors?
by shiny
02/13/16 09:57 PM
Oil filtration and circulation question
by Doublehaul
02/13/16 09:41 PM
Anyone ever replaced brake fluid on Honda Pilot?
by Islandvic
02/13/16 09:19 PM
Unused WIX 51372-051815C2 cut & post
by WellOiled
02/13/16 08:37 PM
-31 this morning...without the wind chill!
by Doublehaul
02/13/16 08:00 PM
Cleaning Throttle body, necessary service now?
by Colt45ws
02/13/16 07:33 PM
[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
02/13/16 07:20 PM
[Cut Open] Fram XG3600 - 9098mi
by DuckRyder
02/13/16 07:16 PM
Tsr71, SubaFool, dookchoppa, Formula413, Cruzingoose
56910 Registered Users
50 registered (B320i, bdcardinal, 901Memphis, 12 invisible), 950 Guests and 132 Spiders online.
56910 Members
66 Forums
244670 Topics
#540058 - 11/05/02 07:41 AM Car's running rough, mileage went down. Ideas?
Ferrari Offline
Loc: Mississauga, ON
Lately my car's been running rough, there's some loss of power, the engine isn't as smooth, there's a strong smell of unburnt fuel when starting the car up in the morning, and my mileage has gone down. It's a 2001 Honda Prelude with 34,000Km, no engine mods.
Any ideas of what it might be?
P.S.: I used Amsoil 5W-30 ASL since new
#540059 - 11/05/02 07:50 AM Re: Car's running rough, mileage went down. Ideas?
BOBISTHEOILGUY Offline
Loc: Ocala, Florida
Basic tune up problems most likely. First and foremost, check your air filter to make sure it is clean and clear. Then look at your plugs and wires. Also look and listen to ensure you have no vacuum leaks.
#540060 - 11/05/02 09:48 AM Re: Car's running rough, mileage went down. Ideas?
digitaldrifter91 Offline
Loc: cali
try and reset ur ecu as a start...tune up is necessary...check for damaged wires as well..
#540061 - 11/05/02 01:28 PM Re: Car's running rough, mileage went down. Ideas?
Patman Offline
Loc: Oakville, Ontario
I know it sounds too soon to happen, but it could be a bad o2 sensor too.
#540062 - 11/07/02 01:24 PM Re: Car's running rough, mileage went down. Ideas?
widman Offline
Loc: Bolivia
First pour in a bottle of Techron (not the cheapies) when you are filling the gas tank.
I'll give you an 80% probability of fixing the problem within the first 50 miles. I've posted several stories about this elsewhere on this board.
If not, it's time to check the rest of the system (plugs, sensors, etc.)
A clogged air filter usuallyonly shows up at higher rpm, so the engine can run fine at idle, but lose power after 2000 or 3000 rpm due to lack of air. (same symptom as clogged gas filter)
#540063 - 11/07/02 03:43 PM Re: Car's running rough, mileage went down. Ideas?
Brad Offline
Loc: Cincinnati, OH
Could be a bad spark plug wire, spark plug or Oxygen Sensor.
#540064 - 12/04/02 12:23 AM Re: Car's running rough, mileage went down. Ideas?
Pete Offline
Loc: Greater Hartford, CT
A little soon for it, but catalytic converters can clog...happened in our Prelude a while back, but it was an 1988.
#540065 - 12/04/02 03:49 AM Re: Car's running rough, mileage went down. Ideas?
Greg Offline
Loc: Port Colborne, ON
he lives in toronto, there's no techron or miles here. [Razz]
#540066 - 12/04/02 04:05 PM Re: Car's running rough, mileage went down. Ideas?
Ferrari Offline
Thanks for all the responses.
I swapped my OEM NGK Platinums with NGK Coppers and it did improve a bit. My air filter is fine and after resetting the ECU it did seem to run smoother, so I'll wait until spring before changing the distributor cap, rotor, and getting Denso Iridium plugs.
#540067 - 12/05/02 05:42 AM Re: Car's running rough, mileage went down. Ideas?
sprintman Offline
Loc: Canberra ACT Australia
Don't forget NGK Iridium plugs?
#540068 - 12/05/02 06:31 AM Re: Car's running rough, mileage went down. Ideas?
TheLoneRanger Offline
Loc: Southeast United States
Ferrari, you apparently aren't getting a check engine light. This rules out having a bad O2 sensor. (Make sure the CE light comes on with the switch, to rule out a blown bulb).
I agree with the previous posts. Do a good tune-up, and if it is still not right, clean the MAF sensor.
#540069 - 12/05/02 07:08 AM Re: Car's running rough, mileage went down. Ideas?
Bror Jace Offline
Loc: Saratoga, NY
The same thing happened to my Dad's girlfriend's 'Lude. Her's was a 1998 or 1999, though. At around 40,000 miles, she complained that it was running rough. I added 1/2 bottle of Red Line Complete Fuel System Cleaner and a full bottle of ispropyl drygas ("Christy's," I think, but I don't believe brand matters).
Problem cleared up right away. I suspect it was water so you might want to try just the drygas (gas line antifreeze) because it's just around $1 and should do the job.
Look in your manual, does it say anything about changing the fuel filter? I don't think it does. Honda considers this component good for the life of the vehicle, I think. That's nonsense. Change it at 50,000 miles.
--- Bror Jace
#540070 - 12/05/02 03:44 PM Re: Car's running rough, mileage went down. Ideas?
dragboat Offline
Loc: Oklahoma
Since you smell gas if the oil is getting black unusually fast I suspect a injector could be hanging when shut down and leaking past the rings into the crankcase. Hit it with something good in the gas tank for a couple tanks running and see what comes of it.
#540071 - 12/07/02 04:38 PM Re: Car's running rough, mileage went down. Ideas?
widman Offline
Loc: Bolivia
How can a country get along without Techron? No Wal-marts?
I have miles on some vehicles and Kilometers on others. Depends on where they were born.
#540072 - 12/08/02 08:53 AM Re: Car's running rough, mileage went down. Ideas?
Patman Offline
They used to sell the Chevron Injector cleaner with Techron up here at Walmart a couple of years ago but stopped for some reason. [I dont know]
