What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Grease that's universal on ALL aspects of car care
by NattyBoh
07/24/16 09:45 AM
Oil made from natural gas?
by Sealbilly
07/24/16 09:18 AM
Rotella line upgraded
by Sealbilly
07/24/16 09:13 AM
Kendall VersaTrans LV for Toyota WS?
by Slick17601
07/24/16 08:03 AM
Clutch problem
by chrisri
07/24/16 07:49 AM
Peppers: do you grow them?
by car51
07/24/16 07:29 AM
Havoline conventional $2.99 at Rural King
by car51
07/24/16 06:35 AM
killing weeds without poisoning well
by oilboy123
07/24/16 01:27 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
86 registered (4WD, andyd, Al, AandPDan, alanwayne1908, aquariuscsm, 7 invisible), 2037 Guests and 14 Spiders online.
58578 Members
66 Forums
252186 Topics
#517876 - 09/10/05 07:25 AM '95 K1500 fluid capacity for f/r diff's, trans pan, and x-fer case?
Islandvic Offline
Loc: South Texas
I have been posting questions recently about my new (to me) '95 GMC z-71 w/ 350TBI, 4l60e trans, manual x-fer case, and 3.73 locking rear diff. It has 166k miles and all original fluids (except engine oil, PS fluid and coolant).
Questions...
What is pan capacity for transmission?
What is front and rear diff capacity?
What is x-fer case capacity?
I am using Wally SuperTech DexIII for the trans and a new filter. I will drain and refill three times then dump a bottle and 1/2 of Red Bottle LubeGuard.
For the x-fer case, I will use Valvoline Maxlife ATF.
For the front and rear diff's, Valvoline Durablend 80-90w GL5 semi-syn.
What do you guys think of fluid choice and do yall know the capacities?
Thanks!
#517877 - 09/11/05 07:23 AM Re: '95 K1500 fluid capacity for f/r diff's, trans pan, and x-fer case?
Jim 5 Offline
Loc: Calgary Canada
I just did all of this.
According to the Chilton's shop manual I have:
Trans: You probably have the 4L60E - 10 Pts.
X-Fer Case: 2.5 - 4.5 Pts depending on which one you have there's 4, and I don't know which the manual transfer case is.
Front Diff (K1500-2500)--> 3.5 Pts (K3500)-->4.4 Pts
Rear Diff: From 4.2 to 5.5 Pts depending on which diff you have. Buy extra for filling diffs and return what you don't use. Filling the front diff is a bit of a hassle and gets messy just because of where the fill hole is located.
Also, consider drilling and tapping a drain hole for your rear diff. It doesn't have one (at least my '98 k1500 with a 14 bolt rear end didn't). It beats removing and resealing the diff cover every time. I did this on my trail vehicle and it makes diff fluid changes a breeze. Well worth the time.
#517878 - 09/11/05 07:25 AM Re: '95 K1500 fluid capacity for f/r diff's, trans pan, and x-fer case?
Jim 5 Offline
Loc: Calgary Canada
Also,
Check out this thread on a home brew trans fluid exchange. You may or may not want to try this. Same truck.
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=16;t=002164
#517879 - 09/11/05 08:26 AM Re: '95 K1500 fluid capacity for f/r diff's, trans pan, and x-fer case?
Islandvic Offline
Loc: South Texas
My mental conversion says......
front diff = 1.75 quarts
rear diff = 2.25 quarts
and I was thinking 5 quarts in the trans pan and you said 10 pints, so good deal.
Thanks JIM 5
#517880 - 09/12/05 02:22 AM Re: '95 K1500 fluid capacity for f/r diff's, trans pan, and x-fer case?
Jim 5 Offline
Loc: Calgary Canada
Hmm..
Let me check my book again tonight. The diffs sound right, but I want to check the trans again.
10 quarts sounds more accurate for the trans...10 pints sounds like not enough.
#517881 - 09/12/05 04:40 AM Re: '95 K1500 fluid capacity for f/r diff's, trans pan, and x-fer case?
Islandvic Offline
Loc: South Texas
jim, I think the trans total capacity is 15 quarts,a dn the pan holds 5 of the 15,
when you did your trans service, how old was the fluid? Mine is 166k miles old.
#517882 - 09/12/05 11:07 AM Re: '95 K1500 fluid capacity for f/r diff's, trans pan, and x-fer case?
Jim 5 Offline
Loc: Calgary Canada
Mine was 48k miles. I try to do it between 40-50k miles. Diffs at about 30k miles
I just checked Haynes manual. 5quarts for a 4l60E when draining trans and replacing filter. It just seems hard to believe. I always thought they were in the range of around 10 quarts.
That's Hayne's and Chilton's that both agree.
