P920711
FF/WS 1GPM
Application Details
Fuel Filter Water Separators Product Attributes
A - OD (Inches): 4.38
B - ID (Inches): 1 1/4-12
C - Length (Inches): 7.44
Product Type Description: FUEL/WATER SEPARATOR SPIN-ON
Primary Application: 1 GPM HIGH PERF FF/WS
Substitution: P920683=3 GPM (longer version)
P920683
FUEL FILTER ASSY. 3GPM
C - Length (Inches): 11.75
Primary Application: 3 GPM HIGH PERF FF/WS
Substitution: P920711=1 GPM (shorter
Substitution 2: version)
Filtermart has a replacement ..$$But..... There are a few that share the same thread.. This is allegedly for a Cummins in a Wix x ref from Donaldson's site.
Part Number: 33116
UPC Number: 765809331167
All Applications
Style: Spin-On Fuel
Service: Fuel
Media: Paper
Height: 11.345
Outer Diameter Top: 4.668
Outer Diameter Bottom: Closed
Thread Size: 1 1/4-12
Drain: None
Gasket Diameters
Number O.D. I.D. Thk.
Attached 4.320 3.820 0.365
The Donaldson
P550687
A - OD (Inches): 4.74
C - Length (Inches): 11.8
D (Inches): 4.39
E (Inches): 3.87
Primary Application: CUMMINS 3309437
Substitution: P550202=Standard Fuel
Donaldson doesn't appear to give the gasket specs. If you can spin off your filter and measure ..you can see what works.
After a little more extensive search of the Don-site. There are only 3 filters using the 1 1/4-12 thread that are FF/WS.
Good luck and kindly share your success with the others on the board.
[ November 25, 2004, 07:24 PM: Message edited by: Gary Allan ]
