The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
Best synthetic oil for cleaning out an engine.
by anylettuce
05/28/16 06:58 PM
2013 ford fusion AC stank.
by leeaspell
05/28/16 06:46 PM
Cesna Citation Mustang - First impressions
by OVERKILL
05/28/16 05:35 PM
5.4 3V under valve cover pics & solenoid failure
by 04SE
05/28/16 03:50 PM
New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
Base Oil Content and Marketing
by MolaKule
05/28/16 03:08 PM
Best OTC fuel injector cleaner
by 007
05/28/16 03:06 PM
A brief BMW R1100RT story
by Finn
05/28/16 02:29 PM
2015 6.7L Powerstroke Fuel Filter Change
by 2015_PSD
05/28/16 12:51 PM
Caliper question
by supton
05/28/16 12:48 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
73 registered (AirgunSavant, anylettuce, 2015_PSD, Al, Abakev, AnthemBassMan, 7 invisible), 1416 Guests and 321 Spiders online.
58001 Members
66 Forums
249533 Topics
Page 1 of 2 1 2 >
#3181369 - 11/07/13 02:15 PM NAPA/supertech/advance auto synth, best for winter
ziggy Offline
Loc: stamford, CT
Hi all! Been doing ALOT of research here, and find myself making a post. Car is a 98 toyota corolla. I like using 10w 30. Belive in better lubircation over a 5w 30. Now with winter coming here in southwest ct...other night it happened again! Have supertech 10w30 dino in, do oil change every 3 months, short tripper. Temps at night got around 42-44..Turning over car, that niose, it hesitated to turn a few cycles. Never that prob with a synthetic.
However, this time reseraching here, since i change it often, the oil, looking at supertech, advance auto or napa. Napa has a sale right now, and i know its VERY close virtually identical too valv synth...for $3.49 quart. Supertech not sure, but thought i read here its pour point was like minus 48 F! i know pour point is just where oil shows little movement...but at minus 48 F good enough for me! I see advacne auto has synthetic as well, and know its not a real synthetic.
Out of the 3, which would give the lowest temp startup. januray feb come its literally going to be 14 degrees at night. 10w 30 is going to be thick n hard too turn..so want a 10w30 synthetic out of the 3 listed. read lots of good stuff here, about wear numbers on supertech as well...
#3181392 - 11/07/13 02:37 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
stchman Offline
Loc: St. Louis, MO
If the manufacturer calls for 5W-30, then use 5W-30. Just because you "believe" 10W-30 lubricates does not actually mean it does.
5W-30 has better cold flowing properties than 10W-30, and if Toyota says to use it, the engine was designed to use 5W-30. Remember at operating temperature, 5W-30 and 10W-30 are the same.
Since you are already at Walmart, Supertech makes a full synthetic 5W-30. IIRC, you can get a 5 quart jug for less than $18. I would personally use Mobil 1 at $24 for the same amount. Walmart also stocks Purolator oil filters, the correct application for your car is the L14476 according to Purolator website.
2013 Chevrolet Silverado LTZ 2WD 5.3L
Amsoil Signature Series 5W-30
Amsoil Ea15K50
#3181404 - 11/07/13 02:55 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
NateDN10 Offline
Loc: Rochester, NY
If you're looking for low pour point, why in tarnation are you using 10W-30?
2005 Chevrolet Cobalt - 95,000 mi.
2012 Mazda5 - 80,000 mi.
#3181413 - 11/07/13 03:02 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
ziggy Offline
Loc: stamford, CT
ok...the oil cap says 5w 30 yes. the book that came with car has the oil chart, above 0 degrees i think it was, 10w30 under 0 degrees F 5w 30 so i am ssuming its ok too use 10w 30 no?
I chose 10w30, becuase reading over time here, how 5w30 may or does sheer. 10w30 to me is more sheer stable, thus=keeping grade. im only doing like 1,500 miles MAX in 3 months, 980-1200 the norm. it also says to change oil every 3,000 miles or 3 months whichever comes first.
ive used 10w30 syhtetics even in the rcent past, on my old 95 neone,. mobil 1 10w 30, valvoline synth 10w30, durblend aa mix kinda 10w 30, all at 13-17 degreees out, car turned over faster than i turned the key. Its when i use dino it crnaks n cranks then ths dry start noise comes form engine, hence forth the sythetic. for when its cold.
Edited by ziggy (11/07/13 03:03 PM)
#3181415 - 11/07/13 03:02 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
SF0059 Offline
Loc: Lynchburg, VA, USA
10w-30 is not going to do a better job of protecting at low temperatures than a 5w-30, whether you are talking syn or dino.
Get a good quality 5w-30 (syn or dino) and use it with confidence. Don't second guess manufacturers recommendations because of a gut feeling or something your grandfather told you, they recommend a given weight across temps for a reason.
2014 Honda Odyssey EX-L/RES: 42K mi, TGMO 0W-20/M1 0w-40 & FU
2013 Toyota RAV4 Limited AWD: 43K mi, M1 EP 0W-20 & FU XG9972
#3181417 - 11/07/13 03:05 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
Rolla07 Offline
Loc: MTL, CANADA
Why would 10w30 be better? I would run either a 5w30 or a 0w30 in that car. If it happens with a 5w30, the issue is other than oil related.
2007 Corolla Red Pearl 138k miles
Pennz Ultra 0w40 & Napa Proselect
#3181418 - 11/07/13 03:05 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: SF0059]
ziggy Offline
Loc: stamford, CT
Its been quite some time since ive used a 5w30 in dead of winter at the temps i listed. jsut seems a cheap synthetic, even if it s fake, gives a better startup..
ive discovered even with 10w 30 as a synthetic car started as fast as ASAP..
But so far, everyone replied seems to htik 5w 30 even dino. dont want the 5w 30 dino to make that crank crank crank, dry start noise.
#3181449 - 11/07/13 03:37 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
tommygunn Offline
Loc: usa
I'd take the Napa synthetic since it's Synpower, and it's on sale at a great price.
However, there's nothing inherently bad about AAP or ST syns. And the Walmart stuff even meets GM's 4718M standard.
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#3181453 - 11/07/13 03:46 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
Zaedock Offline
Loc: Massachusetts
Sorry man, but 10W30 did not cause your 15 year old econo car to make noises at 42-44 *F. Not sure why you would want 10W30 anyway. 5w30, syn or conventional, would be fine year round.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3181517 - 11/07/13 05:43 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
Oregoonian Offline
Loc: Bend, Oregon
Run a 5w30 din....year round, forget about it and sleep well.
Mobil Super 5000 5w30 should work just fine (year round), and its reasonably priced at Walmart. In addition, a Purolator Classic filter(Walmart) should be a perfect combination, with a total cost for a 5 quart jug and Puro filter of abour $18 and some change.
IMO, 10w30 oils are 'old school', and will be off the shelves in a few years.
03' Ford Focus SE(2.3L Duratec PZEV)/ 135K +
QSUD 0w20 / Fram 'Ultra'/ OCI: 7500 +/-
ATF: Mercon V w/Lubegard Red
#3181520 - 11/07/13 05:49 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
toneydoc Offline
Loc: War Eagle
How old is your battery? Did the hesitation have anything to do with old or discharged partially battery? I highly doubt you will notice very much cranking difference at that 42 degree temperature. Maybe get the battery checked out at a part store.
1994 Jeep 146k Castrol 0w40
2014 Camry 14k TGMO 0w20
2010 Sebring 39k Valvoline 5w30
2014 HD Ultra 16k Valv20w50
2012 Toyota Rav4 22k Mobil 1 0w30AFE
#3181581 - 11/07/13 06:43 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
davebarnum Offline
Loc: Dixon, CA
Either this is a post to stir things up, or the guy just doesn't read or heed advice.
Even in a moderate climate, people are using 5w30. Even 0w30. But why are you asking this on an oil board if you don't even pay attention to your oil cap?
David Jeffrey Barnum
2003 Honda Civic LX
#3181621 - 11/07/13 07:18 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
05LGTLtd Offline
Loc: Va
Clean the terminals on the battery, starter, and grounds. I concur with the napa 5w-30 synthetic suggestion.
2005 Legacy GT, Synpower 5w-40
2010 Forester SOHC, Edge 0w-30
#3181651 - 11/07/13 08:00 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
fxrider Offline
Loc: Wyoming
Napa oil - 5w30 for winter - 10w30 for summer on that old beater.
#3181659 - 11/07/13 08:10 PM Re: NAPA/supertech/advance auto synth, best for winter [Re: ziggy]
Propflux01 Offline
Loc: Arkansastan
Originally Posted By: ziggy
.... I chose 10w30, becuase reading over time here, how 5w30 may or does sheer. 10w30 to me is more sheer stable, thus=keeping grade.
I think you have that backwards. Most 10W-30's shear to 5W's in a couple three thousand miles.
use a 5W in your climate. Any of the brand choices you listed would work great.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Page 1 of 2 1 2 >
