- Joined
- Sep 26, 2010
- Messages
- 9,807
Gang,
Here is the 2nd UOA for MS5K in my FX4--yawn! This the 14th total OC and UOA! I was being very conservative in creeping up to find the limit of the oil, but I will definitely go to 7,500 on the next OC (maybe even 8,500--I have some warranty remaining, but not enough to be overly concerned).
Blackstone comments are below and my own thoughts are that synthetics are not always needed, they can be a waste of money, and they are not always "better". If one couples that with the fact that I am using a 5W-20 conventional oil and based on general thoughts, I assume that I am running on borrowed time and I can expect the 5.4L to grenade any day now--ummmm...NOT!
Sarcasm aside, I see no reason to return to a synthetic in this engine; what are your thoughts? Cuss and discuss
Wear metals held low and steady in this sample from the engine. This truck certainly sees a lot of miles, but that's clearly not hurting anything. Honestly, engines that see a lot of use often look better than engines that have low mileage on them. There are no obvious problems developing here that we can see. The viscosity was in the 5W/20 range and no fuel or coolant showed up. The TBN was 2.6 showing plenty of active additive left and the TAN was fine at 4.3. Try 8,500 miles on the next oil. The engine can handle it.
Code:
Year: 2010 Make: Ford Model: F-150 FX4
Engine: 5.4L FFV Transmission: 6R80 Axle: 9.75 Ford ELD (3.73)
CONVENTIONAL > SYNTHETIC
Date: 08/12 06/12 | 05/12 02/12 11/11 09/11 07/11 06/11 05/11 03/11 02/11 01/11 10/10 9/10
Oil Brand/Type: MS5K MS5K | PU PU PU PU PU PU PU PU PU PU PU MC
Oil Viscosity: 5W-20 5W-20 | 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20
API Service: SN SN | SM{A} SM SM SM SM SM SM SM SM SM SM SM
Oil Filter: MC MC | MC MC MC MC MC MC MC MC MC MC MC MC
Air Filter: NG NG | NG{B} MC MC MC MC MC{B} MC MC MC MC MC MC
Lab: BLKST BLKST | BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST
Truck Mileage: 80,927 74,447 | 69,305 62,055 54,575 47,075 39,770 32,280 27,100 21,600 16,600 10,600 4,500 991
Oil Mileage: 6,480 5,142 | 7,250 7,480 7,500 7,305 7,490 5,180 5,500 5,000 6,000 6,100 3,509 991
Aluminum: 2 2 | 3 3 5 3 2 2 3 3 6 3 3 3
Chromium 1 1 | 1 1 1 1 1 1 1 1 1 1 1 0
Iron: 10 10 | 11 8 13 8 9 7 9 10 18 13 10 18
Copper: 2 1 | 2 1 2 2 2 2 3 4 4 5 9 41
Lead: 0 1 | 0 0 0 0 0 0 0 0 0 0 0 2
Tin: 4 0 | 0 0 1 0 0 0 0 0 0 0 0 0
Molybdenum: 3 11 | 48 56 46 47 58 55 54 45 47 52 48 42
Nickel: 1 0 | 0 1 0 0 0 0 1 0 0 0 0 0
Manganese: 1 0 | 0 0 1 0 0 0 0 1 1 1 2 10
Silver: 0 0 | 0 0 0 0 0 0 0 0 0 0 0 0
Titanium: 30 24 | 2 0 0 0 0 0 0 1 0 0 0 0
Potassium: 4 2 | 6 0 6 5 1 0 2 3 4 2 3 14
Boron: 7 9 | 91 249 156 144 156 233 244 230 249 278 258 272
Silicon: 11 12 | 13 11 16 19 21 19 19 17 16 29 45 111
Sodium: 374 284 | 4 4 7 5 3 3 3 4 4 4 4 9
Calcium: 1954 2195 | 2647 3168 3003 3053 2941 2900 2814 2613 2740 2911 2706 2203
Magnesium: 12 15 | 17 15 17 17 16 12 12 11 12 12 12 14
Phosphorus: 624 655 | 688 728 671 668 710 713 676 608 629 691 643 773
Zinc: 738 765 | 762 820 724 743 861 834 813 675 718 774 752 835
Barium: 0 0 | 0 0 0 0 0 0 0 0 0 0 1 16
cSt Visc. @ 100°C (UOA) 8.05 7.73 | 8.34 8.25 7.93 7.80 8.45 8.04 8.14 8.21 8.12 7.72 7.94 7.09
VOA MS5K cSt Visc. @ 100°C 7.48 7.48 | --- --- --- --- --- --- --- --- --- --- --- ---
MOBIL cSt Visc. @ 100°C 8.4 8.4 | --- --- --- --- --- --- --- --- --- --- --- ---
VOA PU cSt Visc. @ 100°C --- --- | 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 ---
SOPUS cSt Visc. @ 100°C --- --- | 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 ---
SUS Viscosity @ 210°F 52.6 51.5 | 53.5 53.2 52.2 51.7 53.9 52.5 52.9 53.1 52.8 51.5 52.2 49.4
Flashpoint in °F 390 {C} | 415 405 420 415 410 425 405 390 410 390 400 390
MOBIL Flashpoint in °F 446 446 | --- --- --- --- --- --- --- --- --- --- --- ---
SOPUS Flashpoint in °F --- --- | 435 435 435 435 435 435 435 435 435 435 435 ---
Fuel %
Antifreeze % 0.0 0.0 | 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Water %
Insolubles % 0.2 0.1 | 0.3 0.3 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.1
TBN 2.6 3.7 | --- --- --- 5.4 --- --- 5.6 4.8 5.3 9.4 7.5 ---
TAN 4.3 --- | --- --- --- --- --- --- --- --- --- --- --- ---
NOTES:
Acronyms:
BLKST=Blackstone | MS5K=Mobil | PU=Pennzoil
{A} Possibly SN in SM bottle; note drop in Calcium
{B} Air filter change; MC=Motorcraft, NG=Napa Gold
{C} Blackstone spilled sample; not enough to test FP and Fuel%
Code:
Fuel %
Water %
NOTES:
Acronyms:
