What is the margin of error for the HFRR test?
by BMWTurboDzl
06/19/13 07:37 AM
Nulon AAT Additive - Now advertising Moly in Oils
by vxcalais
06/19/13 04:47 AM
2008 Kia Rio OCIs
by BlueOvalFitter
06/19/13 04:42 AM
Ferritic Nitrocarburizing
by SteveSRT8
06/19/13 04:11 AM
Some Porsche 911 Love
by zloveraz
06/19/13 02:57 AM
How much are you paying for TC-W3?
by BrewCityR
06/18/13 10:51 PM
Long term use of Honda OEM oil filters
by gregk24
06/18/13 10:35 PM
MMO, again
by CourierDriver
06/18/13 09:56 PM
Discount Tire Direct pre 4th of July sale
by stephen9666
06/18/13 09:36 PM
Lense recommendation for a Canon 60D body?
by Kruse
06/18/13 09:32 PM
Questions about Toyota Celica GT/GTS
by Lillikai
06/18/13 09:21 PM
Is Royal Purple API-licensed dexos1-licensed?
by barlowc
06/18/13 09:06 PM
Snowball, jin1234, BigDuke6, gl10, ufomorme
45904 Registered Users
86 registered (badtlc, 99Saturn, A_Harman, berninicaco3, ac_tc, 11 invisible), 1062 Guests and 245 Spiders online.
45904 Members
64 Forums
195337 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 2 of 2 < 1 2
#2589224 - 04/04/12 07:34 AM Re: What problems using kerosene in a diesel? [Re: TiredTrucker]
Cujet Offline
Loc: Jupiter, Florida
Originally Posted By: TiredTrucker
[quote=bullwinkle]
Really? 2-cycle oil will up the lubricity considerably? Not according to this study...http://www.natbiogroup.com/docs/education/lubricity%20additive%20study%20results.pdf
That study shows that a comparatively tiny quantity of the cheapest 2 stroke oil makes a huge difference. A 0.5% concentration results in a 162 micron improvement. At the tested 200/1 ratio, the cost is mere pennies per tankful.
My tests were done with Penzoil TCW-III Semi Synthetic Premium outboard oil at 100 to 1, a better oil, at twice the ratio. Plus I also used a double dose of Stanadyne Lubricity additive.
I spoke with the HFRR rig tech, he has been doing diesel fuel testing for years. Hence the 3 samples I sent in. They were not my original "guesses" but rather suggestions from the tech, tailored to my engines' needs.
It was his way of showing me what was required to make Jet-A work properly in a precision diesel. You know what? He was right. It took significant additives to make Jet-A meet the requirements.
FYI, there was some discussion between us about the film strength of the 2 stroke oil preventing metal to metal contact and that the Stanadyne product helps prevent scaring when that film strength is insufficient. It was his contention that they were somewhat different in modes of protection.
Turbo's rule.
#2598426 - 04/13/12 09:38 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
Stephen_G Offline
Loc: Mount Holly New Jersey
When i was in the USAF we had several trucks that were certified to run on JP4 (JetB) JP8 (JetA) and Diesel, only thing it said was, performance on jet fuel was lower by a little bit, like top speed was 2mph slower than the diesel only one.
Diesel has to meet cetane requirements, which is similar to octane in gasoline
Kerosene has to have no sulfur due to it being a heating fuel (imangine the smell)
Jet Fuel has to have more additives and meets stricter requirements for water than Diesel and Kero, but has next to none for sulfur.
If you are going to run Kero in a diesel, ensure you put a gal of diesel in to ensure you get some sulfur into it for the fuel pump, new diesels are not as picky for the sulfur as they are designed for ultra low sulfur diesel, but older ones are very picky, read up on the GM 350 Diesel and the fuel pump problems due to ULSD. Use at your own risk.
#2599970 - 04/15/12 05:39 AM Re: What problems using kerosene in a diesel? [Re: JHZR2]
Shannow Offline
Loc: a prison island
Originally Posted By: JHZR2
Kerosine ha a different viscosity characteristic - not necessarily good for moving parts. Believe the aromatics may have been all removed too.
Yeah, back in the day, we used to fill industrial gearboxes with kero and "lap" the gears in under very light load.
aromatics aren't very good in an inside lamp/heater.
Page 2 of 2 < 1 2
