Hard Workers
by AirgunSavant
06/30/16 10:55 AM
which kind of vinegar to use?
by bmwjohn
06/30/16 10:53 AM
0% ethanol gas please
by yvon_la
06/30/16 10:17 AM
Motorex Legend 4T
by Junkie
06/30/16 09:56 AM
2ZR-FE Oil filter Comparison
by Tech819
06/30/16 09:45 AM
Andrews AFB
by AirgunSavant
06/30/16 08:55 AM
Luber Finer cut open
by Tech819
06/30/16 08:42 AM
Meguiars wax
by whip
06/30/16 08:02 AM
Weird problem with laptop. Thoughts?
by d00df00d
06/30/16 07:42 AM
Silverado 6.2L Fram TG 3 years and ~45,000 miles
by DriveHard
06/30/16 07:15 AM
Old bike, new engine -synth or dino oil?
by mr_blackstock
06/30/16 06:56 AM
F1 - 2016 Austrian Grand Prix
by gofast182
06/30/16 06:16 AM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
81 registered (2015_PSD, AirgunSavant, AnthemBassMan, 01rangerxl, 1foxracing, 901Memphis, 7 invisible), 1875 Guests and 13 Spiders online.
58322 Members
66 Forums
251031 Topics
#2586874 - 04/02/12 09:37 AM Knocking sound after an oil change
KNK Offline
Loc: Israel
Hello guys,
I know that this issue already discussed here but this time i have something different.
A couple of days ago i did my first oil change on my own.
Car info and parts used:
* Subaru Legacy 2007 2.0R
* OEM oil filter
* MOBIL 3000 x1 5w40 oil(fully synthetic)
The previous oil was also 5w40 but Liqui Moly.
Everything went great: Did the oil change by the book and took the car for a test drive(about 30 min) and it was great.
On the day after also rechecked the car for oil leaks and started up the engine to be sure - all was 100%.
On the second day went to work and tried to start up the car(was around 14 deg C) - there was a very loud knocking sound coming from the engine,
i've never experienced something like that. I turned off the car and tried to start it again - the knocking continued but
less loud.
Immideitaly took the car to subaru garage and until i came there the knocking disappeared(after around 10 min).
The mechanic told me to wait and to recheck it also tomorow, and he thinks that maybe it the hydraulic lifters that was without an oil.
Now my question - How is it possible that after the oil change i checked the car and it was ok but not ok on the day after?
Can anybody explain what can it be?
Maybe some garbage in the oil prevented from the lifters to seal and the oil drained from the lifters?.. it was just a luck that right after the change it was ok?
Today the car started normally without any knocking.
Any help will be appreciated.
#2586881 - 04/02/12 09:46 AM Re: Knocking sound after an oil change [Re: KNK]
stephen9666 Offline
Loc: USA
Did you check the oil again? Is it still at the proper level?
#2586902 - 04/02/12 10:10 AM Re: Knocking sound after an oil change [Re: KNK]
Doog Offline
Loc: North Coast
If it happens again try replacing the oil filter.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#2586907 - 04/02/12 10:14 AM Re: Knocking sound after an oil change [Re: KNK]
Jeffy_D Offline
Loc: missouri
Did you use the same oil filter that was previously installed. If you using a filter without an ADBV ( anti drain back valve) newer cars can being noisy at start up. I would try Mobil 1 0w-40 or Pennzoil/ shell 0w-40 if the filter isnt the issue.
10 titan 70k castrol magnatec/fram TG
12 sonic 55k AC Delco oil and filter
#2586931 - 04/02/12 10:33 AM Re: Knocking sound after an oil change [Re: KNK]
Eddie Offline
Loc: Florida, Cape Coral
Check the oil level to confirm it is correct. See if this is a one time issue or repeats. If it repeats then, I would change oil filter(possible a bad ADBV). Changing the oil should have no effect on the issue you described.
CX5 Touring 2.5L :-)
#2586961 - 04/02/12 10:57 AM Re: Knocking sound after an oil change [Re: KNK]
KNK Offline
Loc: Israel
"Did you check the oil again? Is it still at the proper level?"
- Yes i did, the level is proper.
"Did you use the same oil filter that was previously installed."
- Yes, it's the same original subaru filter. here is the link:
http://www.ebay.com/itm/Subaru-Original-...a#ht_500wt_1113
"Check the oil level to confirm it is correct. See if this is a one time issue or repeats. If it repeats then, I would change oil filter(possible a bad ADBV). Changing the oil should have no effect on the issue you described."
- Thanks. I hope it one time issue.
#2588501 - 04/03/12 03:53 PM Re: Knocking sound after an oil change [Re: KNK]
mechtech2 Offline
Loc: Chicago Area
Initially, a knock is expected.
But after the first start and warm up cycle, things shold be back to normal.
A bad anti drainback valve in the filter may be a problem.
It happens even with good filters , but it is rare. Cheap filters can drain back due to poor design and implementation.
#2588981 - 04/03/12 09:38 PM Re: Knocking sound after an oil change [Re: KNK]
Whimsey Offline
Loc: The Garden State
Check with Subaru to see if there are any technical service bulletins concerning your condition. Sometimes the dealer is not the most astute as to the TSB out there.
Whimsey
#2589167 - 04/04/12 05:20 AM Re: Knocking sound after an oil change [Re: KNK]
KNK Offline
Loc: Israel
Thank you all for the help!
For now, after a couple of days, the knocking didn't come back.
Hope it was one time issue.
Edited by KNK (04/04/12 05:20 AM)
#2590116 - 04/04/12 09:23 PM Re: Knocking sound after an oil change [Re: KNK]
cjcride Offline
Loc: Ontario Canada
How many kilometers on it?
Edited by cjcride (04/04/12 09:24 PM)
#2591508 - 04/06/12 07:19 AM Re: Knocking sound after an oil change [Re: cjcride]
KNK Offline
Loc: Israel
131000km
