Walmart Canada sale PYB, GTX and Edge Black bottle
by Tech819
36 minutes 13 seconds ago
Specialty store find! S2000 track day application
by Thugzy
41 minutes 22 seconds ago
2011 BMW 335xi 6111mi M1 0w-40 -potassium gone?-
by 89Rustang
Today at 10:21 AM
15" Wheels on Lots of New VW Cars in Showroom
by Boomer
Today at 10:14 AM
2006 Volvo V50 Wagon, reliable?
by pandus13
Today at 09:47 AM
02 Protege oil consumption
by smetzger
Today at 09:31 AM
Misspelling
by callbay
Today at 09:21 AM
Suggest an experiment?
by ToadU
Today at 08:39 AM
FCA to produce no *cars* in the US
by Hokiefyd
Today at 08:37 AM
Zero Emission Power Stations...
by Shannow
Today at 05:52 AM
200k!!!! 2005 legacy gt wagon manual transmission
by madRiver
Today at 05:38 AM
Adhesive protective patch in wheelwell
by dlundblad
Today at 05:02 AM
donsladek, rummy, OILGEEK27, pinjc, Lee_C
58627 Registered Users
94 registered (2015_PSD, 4WD, adolan21, 89Rustang, 2009Edge, 9 invisible), 1831 Guests and 12 Spiders online.
58627 Members
66 Forums
252353 Topics
Page 1 of 2 1 2 >
#2521575 - 02/01/12 08:21 AM How long do thermostats last?
tangojetta Offline
Loc: MN
Just wondering how long do thermostat last since my Ford Frestyle seems to take a longer to warm up. BTW the cas has 144K on it.
06 Ford Freestyle awd ltd
#2521596 - 02/01/12 08:47 AM Re: How long do thermostats last? [Re: tangojetta]
Quest Offline
Loc: beaver land EH?
it varies.
Jpn factory OE units can last an easy 10+yrs. I've seen aftermarket/domestic ones that go bad in about a year's time.
Given your mileage, I would just cut to the chase and replace it anyways.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#2521598 - 02/01/12 08:49 AM Re: How long do thermostats last? [Re: tangojetta]
Roadkingnc Offline
Loc: NC USA
If it takes too long to warm up the check engine light will come on and a code will be set p0128
#2521610 - 02/01/12 08:56 AM Re: How long do thermostats last? [Re: tangojetta]
SLCraig Offline
Loc: London, ON, Canada
Some cars also just take a along time to warm up.
Even with an entirely replaced cooling system, my little Saturn 1.9's used to take forever to warm up in the frigid cold. My Civic is slow too when its well below freezing. My Nissans were never an issue with the bigger 3.5 V6's. Also never replaced a thermostat on a Japanese car, but have on all 3 Saturns I owned.
2010 Civic SI sedan 6MT
SynPower 5w30 | Fram Ultra | Pennzoil MTF
#2521732 - 02/01/12 11:17 AM Re: How long do thermostats last? [Re: tangojetta]
Kestas Offline
Loc: The Motor City
Does it take a long time for the engine to warm up or for the cabin to warm up? It may not be the miles, but may be because it's a Minnesota winter.
#2521772 - 02/01/12 11:46 AM Re: How long do thermostats last? [Re: Kestas]
MNgopher Offline
Loc: Lakeville, MN
What is winter? We haven't really had one around these parts this year.
If its taking longer than it did before, definitely suspect the Thermstat. I've had them last nearly 200,000 miles and I've had them bad out of the box.
#2521845 - 02/01/12 12:49 PM Re: How long do thermostats last? [Re: tangojetta]
JOD Offline
Loc: PNW/WA
do you have a scan tool capable of pulling the engine coolant temp sensor voltage? If so, it's easy to test to see if the thermostat is working correctly. If not, and you have a digital multimeter, you can still test it; however, you'll need to make a jumper wire or backprobe the sensor.
If you want to go that route, I can pull up the voltage parameters from the factory manual. Thermostats are one of those things I wouldn't change unless you know its bad. In my experience you're just as likely to get a bum one out of the box. I will say this car takes a while for the coolant temps to warm up--but if you've noticed a change, you should probably investigate it.
#2522031 - 02/01/12 03:20 PM Re: How long do thermostats last? [Re: tangojetta]
Towncivilian Offline
Loc: Florida, USA
My Pathfinder has its original thermostat at 131k miles and it works fine still. I confirmed via a USB ODBII scan tool which can read the coolant temperature, and warm-up is still fast.
2001.5 Pathfinder SE 3.5L A/T 2WD - ML NG 5W-30/PL14610
2007 Altima S - PU 5W-30/M1-110
2009 G5 - PU 5W-30/XG9018
2012 G37 S - ST 5W-30/PL14612
#2522133 - 02/01/12 05:01 PM Re: How long do thermostats last? [Re: tangojetta]
SEMI_287 Offline
Loc: Up State NY
I'd change it. Mine was bad at 86k when I bought the Grand Am. No wonder there's a layer of varnish on the inside...
2007 Chrysler 300C- Magnatec 0w20, M1
2014 Dodge Avenger- Gulftec 0w20, Wix
2008 Mitsubishi Galant- PU SM 10w30, Wix
#2522232 - 02/01/12 06:05 PM Re: How long do thermostats last? [Re: tangojetta]
tangojetta Offline
Loc: MN
It was working find today, but on Sunday when it got down 13F it took a little longer to warm up.
#2522274 - 02/01/12 06:42 PM Re: How long do thermostats last? [Re: tangojetta]
hooligan24 Offline
Loc: wa state
on a 94 Accord EX a friend has, the t-stat lasted 260k miles and 11 years before he noticed the coolant temps quickly rising on the freeway.
05 Dodge Neon SRT-4 - Mobil 1 SN 0w40
03 Nissan Xterra S/C'ed - Maxlife Blend 10w30
03 Yamaha YZF-R6 - Rotella T6 5w40
#2522296 - 02/01/12 07:02 PM Re: How long do thermostats last? [Re: tangojetta]
Quest Offline
thermostat is just a thermal-mechanical device which does come with finite service life (we call that cycles). They do and can become slow (lazy) as they get older, and when they fail, they would either fail open or completely closed.
Don't be cheep on replacing thermostat on your vehicle as soon as you feel like it's not what it used to. Chances are: it's becoming lazy or it fail to regulate your engine coolant temperature properly, causing excessive fuel consumption, carboning of your combustion chamber, engine runs cold on the highway, or overheats if it shuts off completely.
Q.
#2522307 - 02/01/12 07:11 PM Re: How long do thermostats last? [Re: tangojetta]
MuzzleFlash40 Offline
Loc: Ohio
I've had them fail a few months after installing them. But, I usually replace mine when I replace the hoses and serp belt.
15 Ram Big Horn 4x4 5.7-21k
DuraMAX Syn 5w20 & Mopar
16 Santa Fe Sport AWD 2.4-29k
Cam2 SynBlend 5w20 & OEM
#2522448 - 02/01/12 09:19 PM Re: How long do thermostats last? [Re: tangojetta]
edwardh1 Offline
Loc: Coastal South Carolina
have never replaced on several 100k + toyota and hondas even after 12 -15 years
I know women who are always late, they do not allow travel time, they think like Star trek, you leave one place and materialize somewhere else.
#2522522 - 02/01/12 10:28 PM Re: How long do thermostats last? [Re: tangojetta]
RPMster Offline
Loc: Southern California
Original thermostat in my '06 Sonata is fine at 95K miles. My '00 Accent had the original thermostat until it failed at around 140,000 miles and >6 years of age. Engine started getting very hot, almost overheating, so I changed the thermostat and flushed the (original!!!) coolant, which was looking hideous. The car kept humming right along until I traded it in a couple years later.
Ford 4.6L Panther cars back in the 1990's seemed to need the thermostats replaced around 100K miles or sooner. Dodge trucks over the last couple decades seem to get easily over 100K miles with their original factory thermostats.
Page 1 of 2 1 2 >
