Here is a quick install of a Pareto Top Dog V bypass filter on a 2009 Ford Focus. I've created my own systems in the past, but this time I wanted something that was already engineered and would be much easier to install.
I'm very impressed with this kit. Here is the mounting bracket that comes with the kit for the filter base
I looked all over for a place under the hood to install the setup. I wanted something I could get to without having to crawl under the car. I simply couldn't find a spot. You MAY be able to install it behind the grill, but it would require you to cut a hole in the top of the grill or remove it every time you want to change the filter. Not a great setup.
In the drive side front bumper in front of the wheel well there is a perfect spot. There is already a hole in this area you can use for one of the mounting bracket holes
All you have to do is measure the distance between the holes on the mounting bracket
And drill it out
The spot works very well
This is the orientation I used for the mounting bracket and the filter base. It gives the maximum distance between the filter and the air [censored].
Installed the nipples for the hoses
and the oil lines, making sure to note the inlet and outlet of the base
the base installed in the driver wheel well behind the bumper
The adapter is another high quality unit. With the nipples installed and pre-oiled, ready for install.
Spin the factory off and install the adapter
filter installed, ready to route lines
lines routed and ready to go
Sure gives a lot more filtration media...
Pre-filled both filters with oil, and filled the car up with oil. Took it for a quick drive and checked for leaks - found none!
The factory filter was hot, and the input line was hot.. But the bypass filter wasn't hot. I'm going to drive it tomorrow for a little over 60 miles back from work, and I'll check it again to see if it has warmed up. Really easy install and so far I'm impressed with the quality of this product!
And drill it out
