45569 Members
64 Forums
193964 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2467319 - 12/19/11 02:06 PM
Re: Amsoil's December Magazine - Fuel Economy Study
[Re: Artem]
Loc: Florida
Having read the whole study, i've come to the conclusion that the test is severally flawed with many reasons... - two different trucks
- two different drivers
- too many variables in driver error to accurately calculate fuel consumption
- test truck received a SECOND FLUSH
- A dyno with controlled weather conditions was NOT USED
Looking at the baseline and test results, the before / after numbers of the test truck using Amsoil are so small that i'm shocked how any actual and TRUE numbers were pulled from this. The fact that the test truck received a SECOND flush of all the fluids alone could account for the 6% difference. I feel that it could have gotten the same results with a SECOND flush of conventional lube, since the second flush would help to further remove / clean the internals, helping everything run more efficiently, resulting in improvements. I feel that a dyno and lab controlled testing is the only way to truly spot the difference. Old engines with 750,000 miles of wear should not be used as the testing equipment. A new block that is fully broken in should be used. It's the same with Royal Purple and their silly oil tests. They take a car with old synthetic oil of another brand and run it on a dyno, taking HP readings. They then change the oil to RP and run another dyno which results in more power, claiming that it's their oil which is the cause. ^The same can be had by simply changing the used oil with new oil OF THE SAME BRAND!!
#2467332 - 12/19/11 02:24 PM
[Re: Artem]
Loc: NY
Anytime an increase in fuel economy is mentioned here be it from changing oil to adding something to the gas tank it is quickly challenged here. This is no different, Amsoil paid for the testing, then stuffed it into their own publication. I'll believe some of the members claiming fuel economy increases before I believe some article from an oil company pushing product.
BTW I agree their testing is flawed! Any oil company could have done the exact same testing then pushed their results.
GOD Bless our Troops!
#2467338 - 12/19/11 02:30 PM
[Re: demarpaint]
Loc: Florida
Agreed. I mean, we know synthetic performs better then conventional. Nothing new here.
Now if they got a 6% difference with their synthetic vs another synthetic, THAT would be interesting but in reality, the difference between the two would be 1% +/- since both are high quality lubes and would perform almost identical.
06 Scion tC 108k - 10w30 Valvoline NextGen
1990 Mazda RX-7 - 145k - 15w40 Rotella T
98 Toyota Camry V6 - 239k - Doing Mobil 1 0w40 + MMO cleaning
#2467350 - 12/19/11 02:40 PM
[Re: Artem]
Loc: NJ
Amsoil ....  Thank you for sharing Artem.
#2467352 - 12/19/11 02:45 PM
[Re: Artem]
Loc: NJ
Amsoil also let some noob claim in their magazine that moly is a solid and bad for engines. Amsoil has very tacky and sketchy marketing sometimes.
#2467357 - 12/19/11 02:53 PM
[Re: Artem]
Loc: usa
Being a former trucker driving in a fleet of thousands of trucks, the company I used to work for would be using this stuff if it was true. Everybody would be using it and they wouldn't have to advertise it because a 6% increase in fuel is about $25 a day in savings.
#2467364 - 12/19/11 02:56 PM
[Re: buster]
Loc: Dallas, Texas
It just makes me want more data points.
BTW, Everyone's marketing has questionable ethics. Marketers over sell their wares, engineers over engineer their wares.
Unfortunately It's the world we live in.
#2467367 - 12/19/11 02:59 PM
[Re: Artem]
Loc: Michigan
Looking at the baseline and test results, the before / after numbers of the test truck using Amsoil are so small that i'm shocked how any actual and TRUE numbers were pulled from this. The fact that the test truck received a SECOND flush of all the fluids alone could account for the 6% difference. I feel that it could have gotten the same results with a SECOND flush of conventional lube, since the second flush would help to further remove / clean the internals, helping everything run more efficiently, resulting in improvements. I feel that a dyno and lab controlled testing is the only way to truly spot the difference. Old engines with 750,000 miles of wear should not be used as the testing equipment. A new block that is fully broken in should be used. It's the same with Royal Purple and their silly oil tests. They take a car with old synthetic oil of another brand and run it on a dyno, taking HP readings. They then change the oil to RP and run another dyno which results in more power, claiming that it's their oil which is the cause. ^The same can be had by simply changing the used oil with new oil OF THE SAME BRAND!! How can you conclude that the test was severely flawed when they followed the standard SAE J1321 test procedure? This is the procedure defined by the SAE to test fuel economy of in-service vehicles.
1985 Z51 Corvette track car 2002 Camaro Z28 LS1/6-speed 2001 Dodge Ram 2500 diesel 1972 GMC 1500 shortbed project truck
#2467374 - 12/19/11 03:08 PM
[Re: A_Harman]
Loc: Florida
Well then the testing procedure is bogus. I can achieve a 6% difference in my fuel consumption average by simply letting off the gas 200 feet sooner then test run #1 and bam! 6% difference and i didn't change a thing with the car! A vehicle should be strapped to a dyno AFTER receiving 2 or 3 oil changes of conventional lube having the engine idle for x amount of time between changes to circulate the oil and leave a good film on every part. THEN begin testing. Same with lube #2. Do a few oil changes, running the engine x amount of time to insure the oil has plenty of time to do it's thing and leave a good film on all the internals. THEN strap the car to the dyno and begin testing. That way it's 100% accurate and the oil inside is 100% concentration of oil #1 and it's formulation vs 100% concentration of oil #2 and it's formula. It makes sense to me.
#2467379 - 12/19/11 03:14 PM
[Re: Artem]
Loc: Michigan
Then fire off a note to the SAE telling them that their procedure is flawed.
#2467384 - 12/19/11 03:17 PM
[Re: Artem]
Loc: NY
Well then the testing procedure is bogus. I can achieve a 6% difference in my fuel consumption average by simply letting off the gas 200 feet sooner then test run #1 and bam! 6% difference and i didn't change a thing with the car! A vehicle should be strapped to a dyno AFTER receiving 2 or 3 oil changes of conventional lube having the engine idle for x amount of time between changes to circulate the oil and leave a good film on every part. THEN begin testing. Same with lube #2. Do a few oil changes, running the engine x amount of time to insure the oil has plenty of time to do it's thing and leave a good film on all the internals. THEN strap the car to the dyno and begin testing. That way it's 100% accurate and the oil inside is 100% concentration of oil #1 and it's formulation vs 100% concentration of oil #2 and it's formula. It makes sense to me. +1 Anyone can easily skew mpg test results just by warming up an engine longer, coasting, or changing shift points. Unless I was there to actually see the test for myself I'll never be a believer.
#2467391 - 12/19/11 03:28 PM
[Re: A_Harman]
Loc: NY
Then fire off a note to the SAE telling them that their procedure is flawed. Amsoil ran the test the SAE didn't. If the SAE published those results it would carry more weight, odds are that isn't going to happen. So we have to A$$UME Amsoil followed procedure. What are the odds of the SAE calling them out? Does anyone know? It would help me to learn more that's for sure.
#2467410 - 12/19/11 03:52 PM
[Re: buster]
Loc: Saskatoon canada
Didn't amsoil claim for years that moly wasn't good for engines but now put it in their oil. Don't get me wrong. I like the product for the price. If I had to pay retail I'm not sure if I would like it as much.
2000 mustang 4v Mach powered 1999 lifted chev 4x4 2008 S&S 106" Harley davidson street bob 2005 dodge ram hemi 1988 mustang 5.0 hatch.
