Huffy
by Shellman
8 minutes 29 seconds ago
2012 VW Tiguan; Castrol 0W-40; 54,500 // 4,800 OCI
by motech
27 minutes 58 seconds ago
2004 Chevy Aveo- Auto 1.6L
by AirgunSavant
Today at 08:51 AM
Filter cover?
by Shellman
Today at 08:19 AM
Anyone remember the show "The Moment of Truth"?
by skyactiv
Today at 08:16 AM
2010 Tahoe Z71 Oil, etc.
by SteveP
Today at 07:59 AM
Purolator One and Puro Boss 14006 "Not Cut Open"
by bandz7
Today at 07:04 AM
Nikola Semi
by AirgunSavant
Today at 06:57 AM
Oil Pressure with M1HM 10w30
by lukejo
Today at 05:56 AM
Clay Based HTB Grease
by SR5
Today at 04:33 AM
Which M1 oils are true synthetics
by FordCapriDriver
Today at 04:06 AM
That's unfortunate...or maybe bypass filtration?
by linksep
Today at 02:24 AM
karpouzi, Tapan, shindery, Josh_Westwood, Brogan
58283 Registered Users
78 registered (2010Civic, AirgunSavant, A_Harman, ABerns, ag_ghost, 2015_PSD, 5 invisible), 1784 Guests and 13 Spiders online.
58283 Members
66 Forums
250868 Topics
Page 1 of 6 1 2 3 4 5 6 >
#2458902 - 12/10/11 02:55 PM Of What Use Is An "Upper Cylinder Lubricant"?
OldCowboy Offline
Loc: SW Missouri
MMO and other products are marketed as upper cylinder lubricants.
Why would the upper cylinder need lubricating?
The valve stems and piston rings are oiled by the engine lube system.
Adding oil to the fuel, even a thin oil, would increase the deposits on the spark plugs, valves, valve seats and piston, resulting in combustion chamber problems appearing sooner.
Can someone explain how these products help?
#2458914 - 12/10/11 03:11 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: OldCowboy]
chubbs1 Offline
Loc: Merritt Island FL, USA
Most modern engines today have a lube system that sprays the cylinders, so I agree with you there really is no benefit from these products. Older engines maybe, but I don't "believe" in UCL's. I like MMO for cleaning and fuel system upkeep but I agree with you, I don't think they are of any benefit and more marketing hype. hide
Edited by chubbs1 (12/10/11 03:12 PM)
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2458915 - 12/10/11 03:13 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: OldCowboy]
Turk Offline
Loc: MN
popcorn Oh boy, here we go. LOL
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#2458916 - 12/10/11 03:15 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: OldCowboy]
NHGUY Offline
Loc: USA
Supposed to help lube,or cushion the valve face/seat area,lubricate the fuel system (pump,injectors),and maybe some of the upper areas in the cylinder/bore area itself.How much it really does is a "mystery".
#2458921 - 12/10/11 03:19 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: chubbs1]
NCGuy68 Offline
Loc: N. Carolina
Never heard of this - please explain.
Craig S.
#2458931 - 12/10/11 03:27 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: OldCowboy]
Spazdog Offline
Loc: Arlington
I use it in vain hope of counteracting the effects of ethanol on the fuel pump and injectors. (although I really shouldn't worry on the Chrysler with all the SRT/4 guys running E-85 on the OE fuel pump, many do run a Walbro pump instead though)
2013 Chevrolet Cruze Eco - dealer Dexos
2014 Chrysler 200S - Whatever the dealer put in it.
1987 Honda CN250 Helix - Penn Platinum Euro5W40
#2458934 - 12/10/11 03:32 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: OldCowboy]
Loobed Offline
Loc: Northern California, USA
UCL have been used in alcohol race engines for a long time. Alcohol is a solvent and it will wash oil off the cylinder walls, and cause increased wear. UC lubes are not really needed with normal, non-ethanol, fuel. The use of 15% ethanol in today's fuel have caused people, like me, to add UC lube to the fuel. I do not know if it helps the cylinder walls, but from my personal experience the UCL keeps the fuel system clean and free of corrosion.
I use 2 stroke oil.
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2458940 - 12/10/11 03:35 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: NCGuy68]
Artem Offline
Loc: Florida
Modern engines have piston oil jets that squirt oil UNDER the piston, for cooling and lubricating benefits. That oil also helps lubricate the cylinder walls but that's about it.
As far as upper cylinder lubrication... i call baloney as well. until i see a back to back study done on two engines, one ran with regular fuel and one with the additive and it shows considerably LESS cylinder wall wear, over the course of 200k+ i'll consider BELIEVING in the product but still see absolutely NO POINT in actually spending money on said additives. Waste of money.
2015 Lexus ES300H with all the goodies - Factory Fill
2014 Mazda 3 Hatch i Touring 2.0L & 6spd - Mazda 0w20
#2458951 - 12/10/11 03:46 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: chubbs1]
demarpaint Offline
Loc: NY
Most modern engines today have a lube system that sprays the cylinders, hide
Interesting then all modern engines should be consuming oil needing top offs between OCIs. Many people report no oil use at all. I think if oil is sprayed as a UCL it would be sprayed in on top of the pistons. UCL also refers to a "top oil", oil being supplied to the top of the cylinders, not from the bottom up. AFAIK the modern engine oiling system doesn't oil the cylinder from the top down, does it?
God Bless Our Troops
#2458956 - 12/10/11 03:50 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: OldCowboy]
SS1970chrysler Offline
Loc: PA
Top cylinder wear was much more common in cars from early 50's and older that used a mesh air filter. I've opened a couple that had the upper ring lands completely worn away from debris.
93 Towncar- Rotella T-30+M.Craft
93 CrownVic- QSGB 10w-30+M.Craft
78 LTD- S.Pro XHD30+Bosch
#2459004 - 12/10/11 04:41 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: Turk]
AstroTurf Offline
Loc: Richmond, VA
Again...
#2459012 - 12/10/11 04:48 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: OldCowboy]
AstroTurf Offline
Loc: Richmond, VA
I am currently on my 4th qt of TCW3. Runnin a lil test...
While using it as an UCL, I have no loss of oil from the crankcase.
Without it I have crankcase oil consumption.
What gives?
Jim
#2459018 - 12/10/11 04:52 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: OldCowboy]
Torino Offline
Loc: Henderson, Nevada
For a four cycle engine--none. John--Las Vegas
#2459039 - 12/10/11 05:25 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: AstroTurf]
demarpaint Offline
Loc: NY
What gives?
Jim
I had the same observations with my Aerostar, oil use was less with TCW3 vs. MMO. W/O adding a UCL oil use was more across the board. I believe a top oil makes for a better ring seal in older worn engines. I also believe that TCW3 is better at reducing oil burning than MMO. I think MMO is a better cleaner than TCW3, and a good UCL. Keep in mind oil use can come from worn rings, bad stem seals, bad valve guides, or a leak. A UCL is only going to help if the oil use is caused from ring wear, and it would depend on just how bad the rings are. JMO from experimenting, sorry no scientific data.
#2459066 - 12/10/11 06:35 PM Re: Of What Use Is An "Upper Cylinder Lubricant"? [Re: Turk]
DaHen Offline
Loc: Massachusetts
And we all get a front row seat........
'06 Altima
