Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
Carlson Slide Pins
by SavagePatch
08/27/16 08:07 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
53 registered (3800Series, B320i, Billbert, 69GTX, Astro14, 901Memphis, 6 invisible), 946 Guests and 33 Spiders online.
58943 Members
66 Forums
253655 Topics
Page 1 of 3 1 2 3 >
#2425542 - 11/04/11 11:05 PM 2007 Duramax 8.8k 5w-40 shell Rotella
mikoffey Offline
Loc: Arizona
Here is the oil sample on my 2007 bone stock Duramax LBZ. It goes to show that a good synthetic 5w-40 can perform as good as a 15w-40 in extreme heat "115 degeees" pulling a 15,000lb trailer. I am using Shell T6 5w-40 synthetic. I plan to take to OCI out to the fuel filter change interval.
Shell Rotella T 5W/40 (Syn) 8,827 miles on oil
Code:
ALUMINUM     1
CHROMIUM     0
IRON         9
COPPER       2
LEAD         1
TIN          0
MOLYBDENUM  68
NICKEL       0
SILVER       0
TITANIUM     0
POTASSIUM    0
BORON       41
SILICON      9
SODIUM       9
CALCIUM    853
MAGNESIUM  1259
PHOSPHORUS 1124
ZINC       1282
BARIUM       0
SUS Viscosity @ 210F    75.1
cSt Viscosity @ 100C    14.28
Flash point in F        425
Fuel %                  <0.5
Antifreeze %             0.0
Water %                  0.0
Insolubles %             0.1
TBN                      9.0
{Mod note; 104,463 total miles on vehicle}
Edited by Bill in Utah (11/05/11 07:39 AM)
Edit Reason: changed subject, fixed tables and noted total miles on vehicle
#2425558 - 11/04/11 11:21 PM Re:2007 Duramax 8.8k 5w-40 shell Rotella [Re: mikoffey]
HTSS_TR Offline
Loc: Lake Forest, CA
Very low wear metals and exceptionally high TBN after almost 9k miles. If all numbers are correct, you can run Shell Rotella T6 5W40 to 20k miles in this truck easily.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2425773 - 11/05/11 09:50 AM Re:2007 Duramax 8.8k 5w-40 shell Rotella [Re: mikoffey]
Jim Allen Offline
Loc: NW Ohio
That's an exceptional report. I agree, it's ready for more miles! What is the percentage of highway miles (towing or not) versus stop and go city or short hops? I think long hours in a hot towing environment is better for oil than short hops.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2425776 - 11/05/11 09:52 AM Re:2007 Duramax 8.8k 5w-40 shell Rotella [Re: mikoffey]
KevinsDMAX Offline
Loc: Eielson AFB, AK
Great UOA. I find it weird how the Duramax has the smallest oil sump of the big three, and seems to be the easiest on the oil.
Kevin
#2425873 - 11/05/11 11:49 AM Re:2007 Duramax 8.8k 5w-40 shell Rotella [Re: Jim Allen]
mikoffey Offline
Loc: Arizona
I sell farm machinery so alot of the miles are on dirt roads. I would estimate 60% is hiway miles 20% in stop and go Phoenix traffic and 20% on dusty farm roads. Thanks for your imput on the report I had Blackstone labs do the analysis.
#2425876 - 11/05/11 11:54 AM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: mikoffey]
mikoffey Offline
Loc: Arizona
Thanks Bill in Utah
This was my 2nd post I appreciate the help in cleaning it up a little
#2425942 - 11/05/11 12:54 PM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: mikoffey]
roadrunner1 Offline
Loc: oh
Glad to see the 5w-40 Shell holds up so well in the Duramax, I tried it for three consectitive runs in my 6.0 Powerstroke with sub-par results.
'15 F350 6.7
#2425963 - 11/05/11 01:24 PM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: roadrunner1]
Smokefan1977 Offline
Loc: Gilbert, AZ
Dmax's are easy on Any oil. This is a very typical UOA for these engine. Very well built mills!!
Powerstroke HEUI injection is very hard on oil. The cummins and Dmax use a complete different setup which make them easy on oil. 5K OCI with MC filters only on the 6.0
Edited by Smokefan1977 (11/05/11 01:27 PM)
2000 F350 7.3 4X4- Highly modded. Redline 15-40
99 F150 2wd. Mobil 0-40 MC820S
07 F150 2wd. Ultra 5-30 or Redline MC820S
#2426014 - 11/05/11 02:25 PM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: mikoffey]
roadrunner1 Offline
Loc: oh
I don't have any problems going 7,500 mi. OCI with premium oil (Deere Plus 50 10w-30), I was not able to with the Rotella.
The ironic part of the story is that the Rotella (5w-40) cost is double that of the Plus 50.
Great report to the OP.
'15 F350 6.7
#2426082 - 11/05/11 03:57 PM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: mikoffey]
dnewton3 Offline
Loc: Indianapolis, IN
great report.
Can go WAY past that mileage; I'd think 25k miles would be in line given the low wear and excellent TBN, presuming your circumstances of operation on consistently producing numbers like this.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#2426107 - 11/05/11 04:16 PM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: roadrunner1]
Loc: Gilbert, AZ
Im not saying EOCI can't be done it's just not ideal for the already POS injectors on the 6leaker 7500 isn't to bad for a quality Product but i surely wouldn't push past that with any quality syn in a 6.0.
I have customers that think because they bring me amsoil that they can go 10+K miles. Every one of these customers have had numerous injector failures. It's not always the quality of the product with these trucks but maintance habits more then anything.
I doing a rebuild currently for a customer that the oil temps got so hot the Stand pipe melted. Needs a complete rebuild from top to bottom with a new turbo. The oil cooler became compeltely plugged...I mean SOLID. Guys not even finished paying it off and is putting 12k into the truck. 2006 with 108k on it. This has nothing to do with the filter or oil just the 6.0 issues in general. Get an oil temp and coolant temp guage and monitor the 2 closely
#2426508 - 11/06/11 06:44 AM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: mikoffey]
Ponch Offline
Loc: Bay City Michigan
Im shooting for 25,000 miles with same truck same oil with an amsoil oil filter! My prior 9,000 mile run of rotella dino 15w40 was nothing short of spectacular!
#2427378 - 11/07/11 07:31 AM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: Smokefan1977]
motor_oil_madman Offline
Loc: Houston, Texas
A Coolant filter would have solved that problem so it never would have happened. But lets not get off topic here. Good uoa.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#2427546 - 11/07/11 10:52 AM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: motor_oil_madman]
dnewton3 Offline
So very true, madman. My neighbor has gone through two turbo's because the oil got too hot and didn't cool the turbo well enough. The first time, the dealership only replaced the turbo center section under warranty. This time, his warranty was expired; so we went deep for the root cause. Upon teardown, his oil/coolant heat exchanger was nearly completely plugged. After some internet searching and lots of reading and understanding how the oil and coolant systems are routed on a 6.0L PSD, it's abundantly clear. MOST of the 6.0L problems are associated with this one fault; a blocked coolant/oil heat exchanger. EGR overheating, cooked turbo bearings, coolant spilling from the degas bottle; they all stem from this one problem. Upon his top-side rebuild (turbo, EGR cooler, etc) he also added a coolant bypass kit this time. He has only 75k miles (approximate) on his rig. Sad to think that a $100 investment 5 year ago could have saved him all this grief and thousands of dollars of rework.
Edited by dnewton3 (11/07/11 10:58 AM)
#2427689 - 11/07/11 01:35 PM Re: 2007 Duramax 8.8k 5w-40 shell Rotella [Re: dnewton3]
Loc: Gilbert, AZ
This vehicle had one of Bob Rileys ( Diesel Site ) coolant filters installed. I assure you they do help but it's not a cureall for the issue. The rebuild will include a Bulletprood Diesel EGR coller and BPD Oil Cooler.
Many of these truck expierence 3+ EGR cooler Failures in 100K miles. I have found most dealers don't replace the oil lines nor even flush them and this comes around to Failure of the new coolers pretty quickly. This was indeed the case with this engine. Unfortunately this engine as we all know is poorly designed and it would cost the dealer and warranty a ton to fix them properly. Customer wasn't to happy to have 2 EGR/oil coolers and 1 set of head gaskets done in 100K to find out at 108K is no longer covered. It was still less expensive to fix it right then take a bath on the 6.0 to get a 6.7.....In his case 6.7 cummins. Ford lost him as a customer.
madman it looks your well on your way to educating yourself on the 6.0 and facing the issues headon. I have seen a few roll over 400,000 miles with few issues. Taken care of and knowing the issues these engines can be just as good as anyother
Page 1 of 3 1 2 3 >
