So this is an oil sample I pulled after checking the oil in my Mother in law's car and asking how long it was since it was changed. After she explained how difficult it is to get the oil changed because she has to wait, I went and picked up a filter at her mechanic's (who I am friends with) and a search of his records showed the last oil change in October 2002, with the one prior to that in December 2000 (this is why I know the oil type used and the mileage since last change). She purchased the car with 130,000 miles, so I do not the know the prior maintence history, but it appeared to be well cared for.
Interesting to note, I did a full tuneup when I changed the oil. Since this is a M30 BMW engine, I had to adjust the valves. There was NO sludge at all, with just a thin vanish buildup in the head as I have seen in many BMW motors. Also, this car sees many short trips. Finally, I don't know how much makup oil was added during the two years, except for the quart of Chevron Delo 400 15w-40 I put in one week prior to the change. I have put the car on a twice a year diet of Delo 15w-40 from now on.
Miles on Vehicle: 161,898
Miles on Oil: 11,500
(Items in Bold were flagged)
Element- UOA (Universal Averages for 4100 Miles)
ALUMINUM- 10(5)
CHROMIUM- 13 (1)
IRON- 36(13)
COPPER- 14(7)
LEAD- 7 (9)
TIN- 0 (1)
MOLYBDENUM- 51 (88)
NICKEL- 4(0)
MANGANESE- 1 (0)
SILVER- 0 (0)
TITANIUM- 0 (0)
POTASSIUM- 7 (1)
BORON- 9 (28)
SILICON- 8 (6)
SODIUM- 11 (9)
CALCIUM- 2111 (2067)
MAGNESIUM- 39 (129)
PHOSPHORUS- 777 (889)
ZINC- 1025 (1076)
BARIUM- 0 (0)(0)
SUS@ 210F- 83.9 (should be 82-95)
FLASH PT- 425 (should be greater than 385)
Less than .5% fuel found
0.0% antifreeze found
0.0% water found
0.5% insoluables found
Blackstone Comments:
This oil was run two years and you're right it was way overdue. Wear was extremely high, expecially in the upper-end (alumium, chrom, and iron from pistons, rings, and cylinders respectively), the the oil itself was not in bad shape. The viscosity was normal for 20w/50 and insolubles were still below limits. No fuel dilution or anti-freeze showed up. Universal averages show normal wear from the BMW 3.5L after about 4,100 miles on the oil. Suggest running the next oil nor more than 3,000 miles and resample to monitor. Wear should improve.
My Thoughts:
This oil went a long time, longer than it should have. That said, I expected the numbers to be much worse. When you adjust the universal averages out to 12,000 miles, you see that the numbers that this motor turned in are not out of line. It makes me question how much benifit there is to a good synthetic over mineral in some motors. Obviously, this motor is easy on oil and does not have sludge issues (it holds 6 quarts which helps).
