Why Measure Trans. Fluid with Engine Running?
by doitmyself
05/04/16 07:39 AM
Is Pennzoil discontinuing High Mileage 10W40?
by aquariuscsm
05/04/16 06:55 AM
Lowering vehicle with alternative coil springs
by OlDirty
05/04/16 06:22 AM
Remington R1 1911 or Springfield 1911-A1 MIL-SPEC
by MuzzleFlash40
05/04/16 06:02 AM
2017 Ford F150 3.5 EcoBoost
by DuckRyder
05/04/16 05:25 AM
Ford Powershift Gearbox Class Action (Oz)
by hpb
05/04/16 03:50 AM
Central Mississippi automotive goods
by mjoekingz28
05/04/16 02:11 AM
Free: 5 Quart jug Peak 5W-30
by Indyvwhonda
05/04/16 01:01 AM
Subaru Oil Burning Class Action
by Bandito440
05/03/16 11:43 PM
'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
05/03/16 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
05/03/16 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
05/03/16 10:38 PM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
94 registered (2009Edge, ARCOgraphite, 87sammy, 06AllAmerican, aquariuscsm, 2015_PSD, 9 invisible), 1420 Guests and 293 Spiders online.
57790 Members
66 Forums
248443 Topics
#2341263 - 08/08/11 04:32 PM Ford Escape rear wheel bearing
Eric Smith Online   happy
Loc: Kansas City, KS
I'm guessing this wheel bearing has been toast for a long time. With the spin test it won't even complete a revolution compared to the other sides that's spins at least 5 times. No it's not the brakes. I've never messed with seal bearings is something I can do myself? No place lists just the hub assembly for the rear or even the front.. not sure why? It isn't AWD in case it's asked.
05 Chevy 3500 (Class C RV) 45k (PP 5w30)
04 Escape 148k (PHM 5w20)
02 Focus 128k (MC 5w20)
#2341269 - 08/08/11 04:43 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
JGR Offline
Loc: Ohio
Hi Eric,
If it is like a 2001 ford focus, the bearing is pressed into the rear drum. I bought the drum assembly with bearing already pressed into it for about $30 to 40 dollars. You can press the bearing into the drum if you happen to have access to a press.
The drum nut comes off and then just pull the drum off. The Focus rear drum axle nut is something like 173 ft torque.
Hope this helps.
JGR
Edited by JGR (08/08/11 04:44 PM)
2000 Dodge Dakota 3.9 Magnum 5 Speed.
2001 Ford Focus 2.0 Zetec 5 Speed.
Checkmate!
#2341289 - 08/08/11 05:15 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
Actually it's a bit more difficult than the Focus I think. Finally found out something on it. The rear bearing is pressed into the rear trailing arm. Not sure if I can use this kit to press out the old and press in the new.
http://www.harborfreight.com/rear-axle-bearing-puller-set-66380.html
#2341332 - 08/08/11 05:58 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
Bluestream Offline
Loc: Waterloo, ON
If the bearing is that bad it must have been really loud... crzy
Check the Escape forums for install procedures. Most take them into a shop to have the new one pressed in drive
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#2341348 - 08/08/11 06:10 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
It's getting up there. Guess it was so gradual gotten used to it. Actually thought it was the tires. I think may check with a shop I know. Have to drive it 100 miles down there but he'll be a 1/4 price up here.
#2341428 - 08/08/11 07:12 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
JGR Offline
Loc: Ohio
I am sure you could do it yourself if you had a press, or take the part off and take just the part to have it pressed in, may be cheaper.
I bought the Harbor Freight 12T press on sale for $99.00. Used it to press the front bearing into the knuckle and press in the wheel hub. It was not to bad of a job, except for the bolts rusted from these Ohio winters.
Good luck with whatever you decide.
JGR
Checkmate!
#2341453 - 08/08/11 07:35 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
JTK Offline
Loc: Buffalo, NY
Spin tested it? I assume this is a FWD only Escape? Even so, there will be some resistance from the rear brakes.
I know on my 2008 Hyundai Santa Fe GLS AWD, my rear left went from a very slight rumble (where I couldn't tell which corner it was coming from) to an all out ROAR that was SO unbelievably loud I had to wear ear plugs to drop it off at the shop.
It was expensive too. The hub assy itself was like $270, + labor.
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2341487 - 08/08/11 08:03 PM Re: Ford Escape rear wheel bearing [Re: JTK]
chad8 Offline
Loc: michigan
so buy a used one. hub with the bearing from ebay $25-75.
problem solved. Then you have time to play with the old one and learn how to press it.
#2341563 - 08/08/11 09:08 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
Yeah spin tested.. the other one spun forever that one hardly went once. The brake wasn't dragging but that brake was wore down alot more than the other not sure why. Good idea on a used I think their might be one at a pick it place. There's only three on ebay the rest is for the front. But those are for 05's and hybrids.. not sure the difference. Wish I had a press I'd do it myself.. don't know of any reputable shops up here. Used probably would be cheaper.
#2342082 - 08/09/11 02:16 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
I'm a goof guess I didn't test it after I put it back together but it spins freely today. Guess it's just the tires making so much noise.
#2342491 - 08/09/11 09:05 PM Re: Ford Escape rear wheel bearing [Re: Eric Smith]
The_Eric Online   content
Loc: Iowa
If the pad is worn more on one side, it's a good indication your caliper or it's slide(s) are sticking.
Like was already said before, if your bearing is causing a noticeable drag, then it's also making a heck of a racket. You better look at your brakes first...
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
