What's all this "once a year or sooner" stuff? This is Chicken Little thinking, men!
Here are some figures for you to chew on.
On average, ATF in a trans that has never been serviced contains approximately 265 mg/l of contaminants after 70K miles of service, 90 percent of which are metallic. The particle sizes range from 5 to 80 microns, about 80 percent of them larger than 5u. Depending on the filter you use, let's say 15u absolute, you are only going to get a percentage of that percentage/
Here's a particle Count test from the trans of one of my trucks for context.
ISO Code (3) 18/17/14
>= 2 Micron 3257
>= 5 Micron 1206
>= 10 Micron 334
>= 15 Micron 129
>= 25 Micron 30
>= 50 Micron 3
>= 100 Micron 0
You are going to catch all the particles from 15u and larger and some of the smaller ones. As the filter loads up, it actually becomes more efficient (a process called sintering) so the filter gets better with age.
Ok, lets go back to that 265 milligrams per liter figure, an average developed by Engineers Eleftherakis and Khalil over decades of testing. If you have 12 quarts of fluid, that's about 11.3 liters so there is a total of about 2994 milligrams generated in 70K miles. Let's call it 3,000 mg. Divide that by 70K miles and that's .0429 mg/mile, which we'll call .043 mg/mile.
Let's say your filter can realistically catch 60 percent of that total amount, so that's .025 mg/mile. Purolater advertises their filters hold up to 13 grams of contaminants before the bypass opens, so lets use that figure.
Convert milligrams into grams and you have 13,000. 13,000/.025= 520,000. 520,000 miles to deliver a max load to a filter that can carry 13 grams. Cut it in half and you still are talking upwards of 250K miles. How many miles do you drive per year?
Consider also that you have eliminated the built in contamination as well as that which come from break-in, both of which are included in Eleftherakis and Khalil's 265 mg/l figure. They also state that 75 percent of a transmission's lifetime generation of contaminants come within the first 5K or so miles, so by changin the oil, you have greatly reduced the per mile generation of contamination.
Hopefully, I have disabused you of the need to do annual changes on your new ATF filter. In light of the above information even a 60-80K interval is way, way on the side of caution.
