Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
Difference between silicone caulking ?
by Merkava_4
05/29/16 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
05/29/16 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
05/29/16 05:13 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
55 registered (4WD, 2010Civic, 79Eldor, AirgunSavant, 3800Series, 4 invisible), 1006 Guests and 321 Spiders online.
58013 Members
66 Forums
249580 Topics
Page 1 of 2 1 2 >
#2305540 - 07/04/11 06:24 AM High mileage Chrysler/Dodge minivans w/3.3L
Indydriver Offline
Loc: Indiana
We still love our 2000 Dodge Grand Caravan Sport with the 3.3L. We have done any and all maintenance on this vehicle because we want it to last as long as possible. We recently replaced the entire coolant system (including radiator) to finally solve some long term coolant leaks. The body has held up remarkably well and it drives great. We will be trusting it for two more 2,000 mile trips yet this year.
My current concern is the multiple oil leaks. Our local mechanic is recommending replacement of the valve cover and intake manifold gaskets and quoting $300 for this work which seems fair to me. I'm leaning toward getting the work done but curious if folks think this engine could last another 100,000 or if you think it is at the end of it's useful life.
Edited by Indydriver (07/04/11 06:26 AM)
2014 Camaro 2SS/RS LS3 Vert 10,000 M1
2012 Sienna 50,000 TGMO
2011 Accord V6 50,000 TGMO
2007 Tahoe 90,000 M1
2004 Intrepid 105,000 M1 5W-30
#2305542 - 07/04/11 06:35 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
demarpaint Offline
Loc: NY
If you're referring to the Caravan in your sig line, the engine can go another 100K miles. The problem with them ususally is the transmission. But then again I heard the tranny's sucked in the Ford Aerostar I own and its 2 weeks away from 200K miles. All I did was service it and replace a vacuum modulator. $300 to stop the oil leaks sounds fair, but if all he's doing is replacing the VC gaskets that seems high. If that's the case change them yourself. JMO
God Bless Our Troops
#2305548 - 07/04/11 06:49 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: demarpaint]
Indydriver Offline
Loc: Indiana
Yes, the Caravan in my sig line with 158,000. I hear ya on Chrysler trannies. Our previous Mopar minivan, a 1990, blew it's transmission at only 68,500. Fortunately, that version came with a 7yr/70,000 mile power train warranty and was replaced at their cost. This 2000 model has gone the distance although knowing this, I've have had the trans serviced at 30,000 mile intervals. So far, so good. The quote also includes the intake manifold which I'm not willing to tackle myself, so I can live with the $300 quote.
Thanks for your input.
Edited by Indydriver (07/04/11 06:52 AM)
#2305568 - 07/04/11 07:40 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
demarpaint Offline
Loc: NY
If he is also changing the intake manifold gasket with both VC gaskets go for it. As long as you manitain that tranny and not beat on it you should be OK.
My brother has the same mini van with about 70K on it. What he's been doing with his tranny, overkill and perhaps a bit of a waste by some people's standards, is this. He drops the pan and filter at 30,000K miles, does a fluid exchange via a tranny line. Then after 15,000 miles he evacuates the pan, removing about 3 qts, and refills it. Then at 30K pan drop, fluid exchange. He feels the $15 worth of ATF at the halfway point keeps the fluid clean. He also adds LG red at the recommended amount. HTH
#2305582 - 07/04/11 08:02 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
Chris Meutsch Offline
Loc: Cincinnati
If he's 100% sure that's where the leaks are coming from, then that's probably a good deal. If it's a rear main seal or another location that he's not sure of currently, it could be more than that.
"If the truck starts like butt its probably not your battery."
----cptbarkey, 5/24/16
#2305596 - 07/04/11 08:27 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
Indydriver Offline
Loc: Indiana
I put paper towels down on the garage floor and got five spots 1-2 inches in diameter. By my own visual inspection, there is no question the valve covers are leaking. I suspect that having this work done will certainly reduce the leakage sources and perhaps make it easier to find any remaining leaks. I did just put PHM 10W-30 in a couple of days ago but I'd be really surprised if it stops all these leaks. This engine had a steady diet of 5W-30 Kendall GT-1 Semi prior to this.
This is the first time I've tried a high mileage oil. Should I get it out of there once the gaskets are replaced?
Edited by Indydriver (07/04/11 08:29 AM)
#2306413 - 07/05/11 06:32 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
Hokiefyd Offline
Loc: North Carolina
Give it some time to work. After 500-1000 miles, you might notice the weeping is less. I had a '97 Dodge Dakota with a real main seal leak...but only if I didn't use something like MaxLife in it.
No. In fact, I like high mileage oils. They tend to be a little on the thicker side, which can help keep aging engines quiet. They're nearly the same price as conventional, so if I owned a vehicle with that mileage on it, I'd use the high mileage oils anyway probably.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2306486 - 07/05/11 08:43 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
Indydriver Offline
Loc: Indiana
Thanks Hokie. I will be taking the first trip starting Saturday which will be about 2,000 miles and will wait until my return to re-evaluate. Now that I think about it, I have three long trips this year, not two. I spent some time driving it yesterday and it just drives great. Well worth spending some money on to keep in top notch condition.
I see you are from NC. I will be driving through your great state to Wilmington where we are staying for a couple of days before moving on to Myrtle Beach.
Edited by Indydriver (07/05/11 08:46 AM)
#2306507 - 07/05/11 09:12 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
Hokiefyd Offline
Loc: North Carolina
Sounds good. We go to Wrightsville Beach at least once a year. I like the atmosphere in Wilmington. It's a typical beach-side town, smells like fishing and life is pretty laid-back. We're about 2 hours inland from Wilmington.
Cheers,
Jason
#2306515 - 07/05/11 09:19 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
volvos_rock Offline
Loc: PA
I can say (from expierience) +1 on the HM for helping with leaks. Bought a Volvo 850 in 08' with about 220k on the clock, leaked like a collinder. After about a year, 10k or so, and three oil changes with Valvoline HM it did not leak a drop (still consumed a little, 1 quart in 4 month OCI).
Enjoy your trip!
Edited by volvos_rock (07/05/11 09:19 AM)
Edit Reason: added
Volvo: 09 S80
Volkswagen: 10 Routan
Chevrolet: 98 K1500
Pontiac: 65 Lemans convt
#2306661 - 07/05/11 12:38 PM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
Indydriver Offline
Loc: Indiana
Thanks Rock, good to hear. Like I said earlier, I really can't expect HM to solve my issues. If it does, I will certainly be singing its praises. It will get a good, long, hot run-in on this trip so it will have plenty of opportunity to do what it's going to do. I'll be carrying a couple quarts of back up just in case.
#2308381 - 07/07/11 06:01 AM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
Paulson Offline
Loc: Minnesota
My 94 Intrepid 3.3L has 257K on the clock currently and runs great... transmission slips a little here and there but it's to be expected for that many miles.
I'd say do it and keep the car running... $300 is cheaper than years of car payments!
01 5.3L Suburban 213K - OReilly Syn 5w30/M1-206
94 3.3L Intrepid 264K - Ace 10w30/DW-4670
06 2.0L Mazda 3 122K - O'Reilly Syn 5w20/M1-102
#2308892 - 07/07/11 04:53 PM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Paulson]
Indydriver Offline
Loc: Indiana
Amen to that. The body is in great shape, the vehicle drives really nicely and we've already invested in some major mechanical replacements. Like I said, I'll probably get the gasket work done after this trip. It will be interesting to see what's dripping when we get back.
#2309752 - 07/08/11 02:09 PM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
hypervish Offline
Loc: new jersey
My 96' Dodge Grand Caravan has 230k miles on it (3.8L), but it's on the 4th transmission... yep that's right 4th... that's even the worst part, it's starting to slip again...
I only use the van for hauling parts back and fourth from the junkyard for my uncle's shop, so it's in pretty bad shape.
All the transmissions i installed were Mopar Brand- New but they were still [censored].
I'd keep driving it till the trans. [censored] out then just junk it.
Edited by hypervish (07/08/11 02:10 PM)
2000 Lexus RX300 AWD 234k miles
QS Ultimate Durability 5W-30
Tranny - Castrol Transmax IMV / T-IV
Transfer Case and Rear LSD - Royal Purple 75w-90
#2313176 - 07/11/11 09:58 PM Re: High mileage Chrysler/Dodge minivans w/3.3L [Re: Indydriver]
CBR.worm Offline
Loc: Jupiter, Fl
They seem to be hit or miss. I had one that I used to tow trailers regularly that the tranny never wore out - and it was an '89 grand voyager with the 3.0 and infamous first year A604 ultradrive. A head gasket at 289K was the final nail in the coffin, at that point the van wasn't really in great shape and oil consumption had gotten to be about a quart every other tank of gas (valve guide seals), the A/C stopped working again and none of the power windows would go down, the 'wood' had all blown off the sides and only one speaker worked, but the transmission still shifted better than most do today, I still miss the buzz-click as it would roll to a stop.
Friends of mine had identical vans that had tranny failure after tranny failure after tranny failure. Others had no problems.
I was in an early '00's chrysler minivan a few weeks ago with 237K on it, I could tell it needed motor mounts, but the owner said he had never had any problems aside from squeaks and rattles.
'06 Infiniti G35 Sedan 6MT - 160k
Page 1 of 2 1 2 >
