In the never-ending search for the PERFECT solution to oil for my fleet, I have an idea I wanted to run by BITOG for opinions and feedback.
I own a 2007 Porsche Cayman S. That vehicle sees quite a bit of track time, and I'm very happy with the results I'm getting with M1 5w50 (UOA HERE)
I also own a 2002 BMW 525i wagon (M54 BMW motor). I've been using Mobil 0w40 in the winter and 10w40 HM in the warmer months. No complaints
Here is my thought -- looking back at the UOA on the Cayman's 5w50 oil, it appears to have sheared to a 40 weight oil but still had an enormous TBN remaining (11.1), and was otherwise clean (fuel, insoluables, flashpoint all OK). I wanted to remove it from the Cayman before it sheared any further.
The question is would this used oil I'm removing from the Cayman be suitable for service in the BMW motor?
I tried to simulate the TEMP vs. VISC curve on the Widman.biz calculator; I know the 5w50 visc @ 100C after it comes out of the Cayman (my UOA was 14.4 @ 100C), but I'm not sure if the 40C visc will go up or down after the oil is used in the Cayman. Unless it goes down drastically (VOA = 108 @ 40C), then my used 5w50 is going to be VERY thick at cold temps. This concerns me. I don't think I'd run used 5w50 in colder temps without knowing UOA visc @ 40C and being able to plot the temp vs. visc curve.
Please chime in with any comments or thoughts. I'd love to hear from anyone with experience or data, or who can give me a feel for what happens to visc @ 40C after oil is used.
It would be too easy for me to drain the 8qts of used 5w50 (now sheared to Xw40) from the Cayman, and dump 7qts of it into the BMW for continued service.
Thanks in advance,
Matt
Thanks in advance,
Matt
