Originally Posted By: A_Harman
Originally Posted By: Matt_N
Ok -- new question
Do we know with some certainty what happens to either visc @ 40C or viscosity index (VI) as an oil is used?
For instance, in general, we know that visc @ 100C decreases as an oil is used (assuming no contamination or long OCI, etc). Does the same hold true for visc @ 40C? Does VI stay the same as an oil is used, since it is a proportional measure of visc at 40C and 100C??
The biggest question I'm now trying to answer is whether the used 5w50 oil will be too thick for winter service (temps down to 0F). If I can convince myself with data that it won't be too thick to try it, then I'll do the experiment and report back.
Thanks
Mat
Since this thread got bumped back to the top, I reread it and saw that this question wasn't addressed. In a 5w50 oil, there are going to be a relatively large amount of VII's, which will shear at high temperatures. As a result, the 100C viscosity will decrease, as will the Viscosity index. The 40C viscosity will not change very much.
It's true that when an oil shears, particularly the 5W-50 grade which is notorious for shearing a lot, there will be a drop in the oil's VI. But the oil's KV40 will drop, although not as much as the KV100. If the KV40 didn't drop the oil would become noticeably thicker on start-up as the oil shears and that doesn't happen.
