Happy Birthday Merkava_4
by Trav
05/03/16 04:56 PM
When should you use grease with moly?
by Jetstreamz06
05/03/16 04:54 PM
VOA Motul 4100 Power 15W50
by GermanAutohaus
05/03/16 04:31 PM
Ace Hardware Pennzoil Yellow May 4th to 9th $2.99
by BigD1
05/03/16 04:23 PM
How often to get tires balanced?
by 2010Civic
05/03/16 03:17 PM
Manual says every 10 K on oil changes
by ceast
05/03/16 02:42 PM
Brake fluid ageing?
by LucasDK
05/03/16 02:39 PM
If Anybody has 60K Lying around
by GumbyJarvis
05/03/16 02:03 PM
144$ lot of 48 Fl-400s/L20195 Eq Filters
by GumbyJarvis
05/03/16 01:29 PM
AT Whine
by DWC28
05/03/16 01:14 PM
GM AutoTrak II fluid
by nthach
05/03/16 12:49 PM
GM 2500HD 75w-90 or 75w-110
by Stewart Fan
05/03/16 12:03 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
85 registered (ag_ghost, 2015_PSD, 69GTX, 2oldtommy, 901Memphis, 12 invisible), 1807 Guests and 270 Spiders online.
57779 Members
66 Forums
248418 Topics
#2276038 - 06/01/11 05:14 AM How important is TBN in Choosing an oil ?
vxcalais Offline
Loc: Melbourne, Australia
How much emphasis should be placed on a higher TBN oil for a 10,000 mile drain interval ? I traditionally go for tbn's of around 9 and above etc when choosing an oil. Some oils that have the same oil ratings may only have a tbn of 7 etc. Does this mean less additives or different additives ? For example, most SL/SM CI4 are 9 and above, yet some only have 7 and so on.
Ride - Holden Calais VX GMV6 3.8litre 01
#2276051 - 06/01/11 05:55 AM Re: How important is TBN in Choosing an oil ? [Re: vxcalais]
Colt45ws Offline
Loc: Central Washington
It depends on the chemistry. Some seem to last longer for a given number than others. I wouldnt base much of anything on the starting TBN.
-Colton
2002 Ford Crown Vic PI, 180k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#2276073 - 06/01/11 06:43 AM Re: How important is TBN in Choosing an oil ? [Re: vxcalais]
NateDN10 Offline
Loc: Rochester, NY
In general, an higher starting TBN is better. However, some are better at TBN retention.
This is one place API SN oils should be better than their SM predecessors, for example.
What I typically try to do is to find UOAs with high mileage (7500+) on the oil to see TBN at that point. That's usually more telling than the starting TBN.
2005 Chevrolet Cobalt - 95,000 mi.
2012 Mazda5 - 80,000 mi.
#2276083 - 06/01/11 06:50 AM Re: How important is TBN in Choosing an oil ? [Re: vxcalais]
Jim Allen Offline
Loc: NW Ohio
The best way to judge is by comparing starting and ending TBNs, with both the TBN tests done by the same lab. There are several methods for determining TBN and they read a little differently. You want to compare apples to apples with he same test methodology. That means a VOA with the oil you plan to use. A super-high TBN, around 10+, which you would find more common in the HDEO diesel rated oils, are not necessarily a good thing in a gas engine because they may leave more deposits and poison the cat faster (in a nutshell...much more to that). "High" starting TBN in a gas engine is 7-8. But like was said above, some TBNs start a little lower and hold longer and that counts for more than a high number that may drop precipitously.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2276084 - 06/01/11 06:54 AM Re: How important is TBN in Choosing an oil ? [Re: vxcalais]
vxcalais Offline
Thanks guys, some good advice for me to ponder. Tricky when you see oils with same ratings, claim high additives etc, but TBN's are clearly different.
#2276130 - 06/01/11 08:37 AM Re: How important is TBN in Choosing an oil ? [Re: vxcalais]
INDYMAC Offline
Loc: Magnolia, TX
I think the best way to look at this number is by how effective whatever TBN additives are used in the formula, relative to how well it is keeping TAN in check. A high starting TBN, or even reserve alkalinity at the end of an OCI means nothing if the chemistry of the oil allowed acids to build up unsafely. So, in short, don't pick the oil you want to use based on a higher starting or ending TBN alone. How effective the TBN is in use is more important.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
#2276151 - 06/01/11 09:06 AM Re: How important is TBN in Choosing an oil ? [Re: INDYMAC]
daves87rs Offline
Loc: Michigan
Good food for thought.
“Never argue with an idiot. They bring you down to their level and beat you with experience.”
#2276241 - 06/01/11 11:08 AM Re: How important is TBN in Choosing an oil ? [Re: NateDN10]
Hokiefyd Offline
Loc: North Carolina
I'm not challenging your statement, but asking for confirmation. I don't recall anything in the API SN description that would indicate a better TBN retention, but I'll be the first to concede that I could have missed it.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2276246 - 06/01/11 11:15 AM Re: How important is TBN in Choosing an oil ? [Re: vxcalais]
NateDN10 Offline
Loc: Rochester, NY
Oops, my bad. API SN calls for better ZDP retention, and I assumed that would help TBN as well. After a brief search around the internet, it appears that this is not the case.
#2276377 - 06/01/11 02:14 PM Re: How important is TBN in Choosing an oil ? [Re: vxcalais]
dparm Online   content
Loc: Chicago, IL
It's only one aspect of an oil's performance. I wouldn't let it be the deciding factor.
2011 BMW M3 sedan ZCP
#2276423 - 06/01/11 03:41 PM Re: How important is TBN in Choosing an oil ? [Re: Hokiefyd]
addyguy Offline
Loc: Canada
API SN protocol DOES call for oils to be able to handle E-85 fuels better. Higher alcohol levels, AFAIK, lead to higher contamination of the oils. Oils would have to retain TBN better to be able to handle E-85 fuel, so this first statement is correct.
2003 Mazda Tribute LX V-6, 196,850 miles...DEAD.
MM F1 5W-20 conventional + Bardahl + top-offs.
MM MPH2 filter.
