Egg Casserole
by chiefsfan1
2 minutes 54 seconds ago
What oil would you recommend for my driving?
by Dylan1303
10 minutes 53 seconds ago
Racing oil not recommanded for street use ??
by ST2008
Today at 05:10 PM
Vlad is the oil guy?
by CharlieBauer
Today at 04:56 PM
2015 Tacoma 4.0 V6, 9.8K mi. Amsoil Signature 5W30
by btanchors
Today at 04:54 PM
Sounds of Black Holes Merging
by MolaKule
Today at 04:53 PM
BEST BROWSER?
by Eddie
Today at 04:46 PM
Are Cooper CS5 LRR?
by Stewart Fan
Today at 03:14 PM
Camry battery tested bad.
by chiefsfan1
Today at 03:08 PM
Electricly conductive grease for Samsung Galaxy???
by Drew99GT
Today at 01:40 PM
Right Oil and OCI for my Application?
by lancerplayer
Today at 01:06 PM
AZ card 20% off, AAP card 13% off
by gojoneeded
Today at 12:44 PM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
88 registered (86cutlass307, andrewlg, AEHaas, 09_GXP, ag_ghost, AIRJAC3, 8 invisible), 1533 Guests and 9 Spiders online.
58973 Members
66 Forums
253822 Topics
Page 1 of 3 1 2 3 >
#2203066 - 03/17/11 12:10 PM Coolant change in 2004 Impala
ljbrandt Offline
Loc: AL
I'm looking for a little advice. 2004 impala 3.4L ~99k miles and the coolant has never been changed. I also notice/hear some gurgling in the dash when making turns and accelerating from a stop, usually only when the car has been running for 10 minutes or less. I am assuming that this is air in the system from other posts I've read.
Anyway, I've read about Dexcool class-action settlements and so-fourth and I have a few questions:
What fluid do I need to use for the change?
Can I change it myself, or do you need someone with an exchange machine?
Anything else I should be concerned with?
Thanks in advance!
#2203087 - 03/17/11 12:24 PM Re: Coolant change in 2004 Impala [Re: ljbrandt]
Drew99GT Offline
Loc: Colorado Springs
These engines are known for lower intake gasket failures. It's essentially inevitable that the gaskets will fail and leak coolant into the oil. That would be my first priority. Is the coolant level consistent, or does it drop often?
As far as changing the coolant, you certainly can drain the radiator. That will get about 4/10th of the total system capacity drained, so about 3 drain and refills will replenish most of the coolant. If you decide to get the gaskets replaced, the entire cooling system will be opened up so the coolant will be replaced.
I'd recommend using Peak Global Lifetime coolant. It doesn't have the gasket eating 2-EHA organic acid in it. It's also silicate and phosphate free. It's the most suitable replacement for Dexcool.
#2203108 - 03/17/11 12:39 PM Re: Coolant change in 2004 Impala [Re: Drew99GT]
ljbrandt Offline
Loc: AL
Thanks for the quick answer!
The coolant level has remained steady and have yet needed to fill it up.
So no-go on a Dexcool-to-Dexcool fluid replacement - even as GM recommends? I'll look into the peak lifetime formula.
Is it unheard of to take your own anti-freeze to a shop to use in their machine?
#2203485 - 03/17/11 07:14 PM Re: Coolant change in 2004 Impala [Re: Drew99GT]
SLCraig Offline
Loc: London, ON, Canada
I'd use something like Peak as well, but you can't mix coolants, or you get a gel like sludge in your cooling system greatly reducing its effectiveness.
If you are going to switch types, get it ALL OUT. If you just want to drain and fill gradually, just replace with the same that is in there.
2010 Civic SI sedan 6MT
SynPower 5w30 | Fram Ultra | Pennzoil MTF
#2203880 - 03/18/11 07:22 AM Re: Coolant change in 2004 Impala [Re: ljbrandt]
BlastChamber Offline
Loc: WI
GM redesigned the intake manifold gaskets for the 2004 model year, so your Impala should not be as susceptible to gasket failure as engines made in previous years.
That being said I would definitely drain and refill with fresh Dex-Cool at a bare minimum to prevent any sludge problem. My 2004 Chevy Venture has not had any intake or Dex-Cool problems, and I drain/refill the coolant every 3-years just to be safe.
'03 Dodge Ram 2500 SLT QC 2wd Cummins 24-valve
#2203914 - 03/18/11 08:03 AM Re: Coolant change in 2004 Impala [Re: BlastChamber]
Boss302fan Offline
Loc: Oconomowoc Wi
DITTO. Good to drain ANY coolant every 3 years or so... This happens to be something that so many owners forget to do.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#2204131 - 03/18/11 11:41 AM Re: Coolant change in 2004 Impala [Re: BlastChamber]
Drew99GT Offline
And people are reporting that they still leak!
#2205034 - 03/19/11 10:00 AM Re: Coolant change in 2004 Impala [Re: Drew99GT]
onion Offline
Loc: kansastan
+1. The redesigned intake gaskets have metal inserts that prevent crushing the gaskets due to over-torquing. And they changed the seal bead material. But GM didn't address what is IMO the fundamental problem with this gasket design- their plastic frame. The plastic still deteriorates and cracks... and the gaskets still leak. It's not a matter of 'if', but 'when'- even with the new-style GM gaskets.
FelPro makes a re-designed gasket that holds up much better. It's a metal-framed gasket with rubber sealing beads- and it holds up much better than the GM gaskets.
Personally if I had a 2004 Impala with a 3400, I would replace those intake gaskets, flush the cooling system with distilled water, and refill with G05. IMO there's no reason to wait for the intake gaskets to fail- because they WILL fail. And when they do, they can dump coolant into the oil and destroy the rest of the engine.
The invisible and the imaginary look exactly the same.
#2208019 - 03/22/11 08:05 AM Re: Coolant change in 2004 Impala [Re: ljbrandt]
Boss302fan Offline
Loc: Oconomowoc Wi
You are probably correct about the 3400 but not everyone has had problems. As most GM cars with issues, it is hit and miss... Not every 3400 or 3800 has had leaks. BUT, here at this site we hear about all the bad gaskets. LOL.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
Other fun cars
#2208357 - 03/22/11 01:57 PM Re: Coolant change in 2004 Impala [Re: ljbrandt]
ljbrandt Offline
Loc: AL
Would it be okay to do the dexcool flush/fill myself using the prestone video guide or does the equipment at a lube place do it much better?
Edited by ljbrandt (03/22/11 01:58 PM)
#2208472 - 03/22/11 03:59 PM Re: Coolant change in 2004 Impala [Re: ljbrandt]
mechanicx Offline
Loc: Ohio
What prestone video guide? Is it the one where they tell you to drain the radiator, refill with superflush and water, drain radiator, refill with water then drain radiator, so 3 radiator drains? That will get most all of the antifreeze out. It's a little time consuming and I think the Impala's radiator drain is a little hard to access. You can also remove the lower radiator hose but that is probably not any easier. Another option is to install a T-flush in the heater inlet hose. This is probably easiest and most effective way.
As far as antifreeze choice, I agree with most of what onion said. Although I don't think using Dexcool or using another type is going to make much difference one way or the other with the gaskets. But one problem I see with the Impala is it has the cap on the radiator and Dexcool can sometimes gum with that setup, especially aftermarket Dexcool. I'd suggest Havoline Dexcool if you are going to go with Dexcool. It's a slightly different formula and seem to be more resistant to gumming. Other antifreeze suggestions, Peak Global Life from NAPA or Peak Professional from Pep Boys and G-05. And also change the radiator cap to a Stant 10230 or 11230 spring center cap that does a better job of keeping air out of the radiator. These are my standard suggestions with working with this year and make.
#2208645 - 03/22/11 07:08 PM Re: Coolant change in 2004 Impala [Re: mechanicx]
ljbrandt Offline
Loc: AL
Thanks for the advice!
Questions:
Where can I find Havoline Dex-cool?
What is the best flush kit (t-adapter) for my application and will I not then need to use the radiator drain bolt?
Do I need to use a chemical flush additive (such as in the prestone vid)?
Any issues with flushing with non-distilled water (garden hose)?
What is the best way to get the air out of the system?
#2208861 - 03/22/11 10:06 PM Re: Coolant change in 2004 Impala [Re: ljbrandt]
mechanicx Offline
Loc: Ohio
Questions:
The only place I know of beside GM dealers is NAPA. they also carry Peak Global and G05. PEP boys carries Peak Professional.
The Prestone T-flush kit would work fine. You will not need to use the radiator except to drain the excess water out before adding antifreeze. Although as the T-flush directions show you can displace the water by filling through the T-flush or the radietor with the t-flush cap off. I'd recommend draining the water out of the radiator though.
That depends on how gunked up your cooling system is.
Normally tap water is not a problem with dexcool as long as it's not really hard water.
There is a bleeder that you open and fill the system until a steady stream of fluid comes out of the bleeder. You'll have to just run the car with the heater on until the thermostat opens.
I don't realize the answer were going to be colored in purple, was aiming for blue.
#2208927 - 03/22/11 11:56 PM Re: Coolant change in 2004 Impala [Re: mechanicx]
scott37300 Offline
Loc: Wisconsin
I did my 04 3800 a couple months ago and here is my advice.
You don't need a flushing machine to do it. Also don't need a T-flush kit that you have to cut your heater hoses to use. Here is what I did. Take the splash shield off the bottom of the car, it's like 4 bolts and will let you access the petcock easier. Open the petcock and drain the radiator. I went threw the process of multiply drain and fills using distilled water, something like 90 cents a gallon at walmart. Just fill the system up run till hot, heater on hot with fan off. Then drain and refill. After this I filled with new dexcool, straight dexcool and not the premixed stuff. I knew the total cooling capacity and since there was already some distilled water in the system I added half the capacity of dexcool. I think my system was 12 quarts total so I added 6 quarts straight dexcool, hope this makes sense. There is a bleeder valve on your engine, not sure where it is for the 3.4 but the 3.8 it was above the thermostat. I replaced the radiator cap, it's only a couple bucks and can make sure there is a good seal. I also had to add some coolant a couple times after driving for a while. Nothing major, just a little bit to the radiator, must have had a little air in or something. But after adding a splash 2-3 times it has been fine since and hasn't gone down at all.
Hopefully this helps a little. I was in your shoes a while ago and had lots of questions. Seems like everyone has there own opinion on what's the best way to do a coolant flush. It's easy to do and will only cost you the dexcool and some distilled water.
#2209188 - 03/23/11 10:40 AM Re: Coolant change in 2004 Impala [Re: scott37300]
ljbrandt Offline
Loc: AL
Scott37300, how many times did you end up filling and draining with distiled water before it drained clear? And when you initially drained the old coolant, were you able to get the fluid from inside the heater core as well?
I'm thinking about making a youtube video for this process to help others out like myself with this generation Impala. I just want to work out all the kinks and know what to expect before jumping all in :-)
Page 1 of 3 1 2 3 >
