Kawasaki must be completely full of gas to start
by jrcowboys
16 minutes 34 seconds ago
Un-Screwing
by Ducked
47 minutes 58 seconds ago
BG 109 vs 120, any techs experienced w/ both?
by dccode
Today at 08:24 PM
Harder on engine, idling or restart?
by mattri
Today at 08:20 PM
Solvent/cleaner + 2 stroke oil for piston soak
by OldEuroCarLover
Today at 08:09 PM
Costco Canada Michelin wiper blades $9.99
by JC1
Today at 06:47 PM
Havoline Car Giveaway
by SatinSilver
Today at 06:47 PM
Opinions please
by ceast
Today at 06:41 PM
UOA, Pennzoil Platinum 5W30, 15K KM, 10 months
by ST2008
Today at 06:19 PM
Cruise control going downhill
by Donald
Today at 05:58 PM
O'REILLY SYNTHETIC OIL
by dooscoop32
Today at 05:10 PM
Anyone here a ice road truckee?
by car51
Today at 04:42 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
86 registered (barkingspider, 4WD, 9C1_guy, 2015_PSD, Bandito440, AirgunSavant, 6 invisible), 1357 Guests and 35 Spiders online.
58935 Members
66 Forums
253600 Topics
#2166418 - 02/09/11 04:52 PM Using AT-205 Re-Seal Topically
Frbl Offline
Loc: Philly, PA
A certain internet auto repair and maintenance "guru" has recently recommended using AT-205 Re-Seal on certain chassis parts to stop squeaks.
It is usually used directly in the oil sump to fix seal leaks, but the idea here seems to be be one of preserving or perhaps renewing things like bushings.
What little I have found on BITOG simply mentions that it is a plasticizer, seems not to contain petroleum distillates, and has mixed reviews from some BITOGers. Most objections seem to relate to its use inside the oil sump or transmission.
I am thinking of using it topically as preventative maintenance on bushings, brake lines, and cv boots. Does anyone have am opinion on whether this would be a waste of money, potentially beneficial, or possibly destructive?
I have been using 303 Protectant, but I wonder if AT-205 might not just preserve but actually restore these items.
#2166467 - 02/09/11 05:37 PM Re: Using AT-205 Re-Seal Topically [Re: Frbl]
willix Offline
Loc: minneapolis mn
Interesting thought, I am not familiar with thew product you speak of. The only thing I don't follow is the concern over bushings.
I like the Idea of using the treatment on only the leaking seal.
I would think the effectiveness may be limited however you would be able to treat the seal with full strength product instead of using it as an oil additive.
I could imagine the boot becoming soft & stickier when bellows make contact with eachother.
Many times seals fail due to wearing a groove in the rotating steel or iron surface.
Brake lines & boots may be a bad idea. If it soaks thru the brake hose plys it will compromise its ability to retain its burst specifiaction.
CV boots only need silicon spray to preserve & prevent the bellows from binding together.
Edited by willix (02/09/11 05:49 PM)
96 Eldo, M1 5W30 EP
2010 Fusion SEL 2.5L M1 5w20 EP
#2169324 - 02/12/11 05:29 PM Re: Using AT-205 Re-Seal Topically [Re: Frbl]
dailydriver Offline
Loc: Bucks County, Pa.
I have actually used this stuff for RUBBER suspension bushings ONLY (I would NOT put it on rubber brake lines, and would be hesitant to use it on steering rack/CV joint bellows).
I buy the liquid bottle and pour it into a pump spray bottle.
DO NOT put too much of this on or it WILL turn the bushing you are trying to swell/quiet to MUSH.
Just wet it slightly and let it soak in.
It DOES work for me, especially on the front lower control arm rear bushings which are a PAIN to replace. wink
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#2169835 - 02/13/11 09:35 AM Re: Using AT-205 Re-Seal Topically [Re: dailydriver]
Frbl Offline
Loc: Philly, PA
Thanks for the warning. I was tempted to do exactly as you describe regarding the non-bushing components. Just 303 Protectant for them!
#2169840 - 02/13/11 09:38 AM Re: Using AT-205 Re-Seal Topically [Re: Frbl]
Vikas Offline
Loc: NorthEast
The only place that I have found this is from Amazon merchant which tacks on shipping. Any cheaper source of it?
Yah, I like that internet "guru" along with RichPin, EricTheCarGuy and RealFixesRealFast. Anybody else is a hack or don't know how to keep camera on a tripod.
- Vikas
Edited by Vikas (02/13/11 09:40 AM)
#2169855 - 02/13/11 10:08 AM Re: Using AT-205 Re-Seal Topically [Re: Vikas]
Frbl Offline
Loc: Philly, PA
- Vikas
I found it locally at a locally owned auto store. Besides Amazon, I have not been able to find it online either.
#2171317 - 02/14/11 07:16 PM Re: Using AT-205 Re-Seal Topically [Re: Frbl]
dailydriver Offline
Every single Napa I've visited in my area has it right on the shelf (some even carry the small aerosol can version as well).
A lot of the independent stores also have it on the shelf.
M1-206 oil filter
#2171724 - 02/15/11 09:20 AM Re: Using AT-205 Re-Seal Topically [Re: Frbl]
Vikas Offline
Loc: NorthEast
Can somebody get me a NAPA part number that can be looked up?
#2172868 - 02/16/11 01:14 PM Re: Using AT-205 Re-Seal Topically [Re: Vikas]
willix Offline
Loc: minneapolis mn
Edited by willix (02/16/11 01:17 PM)
96 Eldo, M1 5W30 EP
#2173180 - 02/16/11 07:14 PM Re: Using AT-205 Re-Seal Topically [Re: Frbl]
Vikas Offline
Loc: NorthEast
Thanks for nothing :-(
You think I did NOT search on NAPA online for this particular product?
- Vikas
#3459424 - 08/19/14 10:38 AM Re: Using AT-205 Re-Seal Topically [Re: Frbl]
babbittd Offline
Loc: Massachusetts
This is an old thread, I know, but I have never seen AT-205 in a NAPA store, or any other for that matter. Which may just mean that it not available OTC in this area.
However, I did find another internet retailer that sells it and I think the shipping charge is lower than amazon's.
http://www.summitracing.com/parts/atp-at205
