Vavoline next gen motor oil?
by gmh101357
Today at 12:10 AM
Thin oil, thick oil, synth or dino,
by Cruzingoose
Yesterday at 11:25 PM
Compete today? Modernize your skills on own time
by spackard
Yesterday at 11:23 PM
Castrol 0w30 leaving Advance Auto Parts
by bbhero
Yesterday at 10:53 PM
Oil Change Marathon Today
by BlueOvalFitter
Yesterday at 10:01 PM
Raybestos Advance Tech or Police Rotors?
by shiny
Yesterday at 09:57 PM
Oil filtration and circulation question
by Doublehaul
Yesterday at 09:41 PM
Anyone ever replaced brake fluid on Honda Pilot?
by Islandvic
Yesterday at 09:19 PM
Unused WIX 51372-051815C2 cut & post
by WellOiled
Yesterday at 08:37 PM
-31 this morning...without the wind chill!
by Doublehaul
Yesterday at 08:00 PM
Cleaning Throttle body, necessary service now?
by Colt45ws
Yesterday at 07:33 PM
[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
Yesterday at 07:20 PM
Tsr71, SubaFool, dookchoppa, Formula413, Cruzingoose
56910 Registered Users
25 registered (deoxy4, akela, Bill_G, Boczech, daves87rs, 4 invisible), 518 Guests and 100 Spiders online.
56910 Members
66 Forums
244671 Topics
Page 1 of 2 1 2 >
#2127439 - 01/04/11 06:56 PM Difference between Rotella T and Rotella T1 30wt.
VWguy Offline
Loc: Los Angeles, Ca
Recently built an air-cooled VW engine and used a Web Cams regrind. They stated it was ok to use Shell's Rotella 30wt oil to break in cam and lifters. I was able to locate a few gallons of the older version of this oil. The replacement oil, called T1 has lost its gasoline engine rating. Is this oil any different than previous version? I've heard that Shell's web site is vague but a lot of the muscle car web sites love the Rotella. Opinions and/or facts welcome. I am in Los Angeles and still find the older version Rotella T 30wt at Napa and Auto Zone outlets. I plan on using Web Cam products in the future so I would consider buying up remaining old stock Rotella if there is a difference between the two. Did the "SJ" rating become obsolete? The two Rotella bottles have the same MFG bar code, if that means anything. Here in So Cal Chevron's Delo 400 is readily available for the Detroit Diesel 2 strokes, but 40wt is most prevalent. Appreciate your feedback. Bill
#2127473 - 01/04/11 07:16 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
JRed Offline
Loc: Virginia
Rotella T5 10w-30 has no gasoline specs either, if that matters - it's got a ton of ZDDP, though (just like that SAE30).
I don't see why you couldn't use T5 10w-30 or even T3 15w-40. Are those air-cooled engines really picky about the type of oil they're fed?
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2127489 - 01/04/11 07:38 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Delo 400 is actually a 4-stroke diesel oil-Delo 100 is the DD 2-stroke oil-T1 is also a DD 2-stroke oil/CF-2 rated. When I had air-cooled VWs they were rated for straight 30, but they were all older ('64 Bug and a '73 Type III Squareback)-I would stick with a high ZDDP oil, not sure about the CF-2 rated oils )which are lower in sulfated ash for the DD. therefore lower TBN. I would think that any modern oil would be fine in an air-cooled VW after cam break-in, but either an SL or older or a ZDDP or moly additive would be a good idea if you have to use SM or SN oil for break in.
06 Ram 3500 CTD 4X4 48RE SRW, 93 GMC C3500 6.2 diesel, 89 F-450 7.3 IDI, 98 Cherokee 4.0, 05 Scion xB, 15 Transit 250 3.7
#2127557 - 01/04/11 08:19 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
Steve S Offline
Loc: East of IGO
The oil will be fine for the engine. The Rotella 30wt is a straight visc.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#2127584 - 01/04/11 08:39 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: JRed]
VWguy Offline
JRed, Rotella 10w-30 not readily available here in So Cal. I agree the 15w-40 oil is a great oil, as I am using it right now since the cam is "broken in", but a lot of the aftermarket cam grinders still recommend a straight weight dino oil, and I wanted to keep Web Cams happy if I had an issue with their product. Air-cooled cars(VW-Porsche) probably are not that picky about the oil selection in a stock set-up but there is a lot of threads on VW-Porsche cars having devastating results when modified with aftermarket cam/lifters and heavier springs.
Bulwinkle, my bad about the Delo 400/100 differences. Currently doing push-ups. I do not think I need to worry about the TBN as my current VW bus engine has 2 oil filters(L39001 full flow and B164 by-pass) and with a sump holds 7 quarts of Rotella 15w-40 CJ4+ oil. Back in the 1970's the VW dealers used straight 30wt and the Porsche dealers used straight 40wt. The multi-grades were not readily accepted by the German dealers. And recently, Castrol came out with a memo or bulletin stating that their, very popular with the air-cooled crowd, GTX oils were not recommended for the older classic cars. I do not know if Castrol dino has moly added to boost the additive package such as Chevron/Havoline or Pennzoil. I have read quite a bit about the lack of ZDDP in the over the counter oils plus the available additives to make up the difference. It's just a little tough trying to convince VW owners they have to purchase an additional product for their crankcase! Rather just choose a decent petroleum product to keep everyone happy. Thanks again, Bill
#2127586 - 01/04/11 08:41 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
edhackett Offline
Loc: Sequim, WA
That is not true. T5 carries the SM rating.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
#2129338 - 01/06/11 10:14 AM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
VWguy Offline
So, is the consensus that the two are the same oil? I'm just looking for an affordable and easily available oil for initial break in with mild air cooled VW engines. I still see the earlier version on the shelves of some Napa's and AutoZone's at about $16 per gallon. I am willing to buy a few gallons as Web Cams is ok with this oil for break in. And from what I've read on one of the air cooled forums, Web Cams will warranty their parts if their instructions are adhered to. Thanks, Bill
#2131919 - 01/08/11 11:11 AM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
Texan4Life Offline
Loc: Texas
If I had to bet, I would say they are the same and shell just dropped the ratings because of cost. I'd image straight 30 isn't one of their big movers.
but, the ultimate would be a VOA of the two.
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#2194576 - 03/09/11 06:58 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
FiremarshalRob Offline
Loc: Baton Rouge, LA
Did anyone ever determine for a fact if the OIL changed, or the SPECIFICATION changed regarding the new bottle T1?
I'd like to know also.
Rob
I have a tendency to be rather OCD regarding my vehicle maintenance.
2008 Nissan Altima 2.5S
2006 Silverado 5.3L
1996 1.3L Geo Metro
#2195766 - 03/10/11 05:47 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
ag_ghost Offline
Loc: SF Bay Area, CA
FWIW, I was able to purchase via special order 10W-30 Rotella dino (T3 with a SM rating), last January in Northern California; in gallon containers from O'Reilly's (formerly Kragen) and quart bottles through a local Shell service station. I think with sales tax it averaged about $4.15/quart from either source. There are date stamps on the packaging if anyone wants me to check. I was on a path to get some Delo 400 10W-30 from a distributor, but it's a 90 minute drive and was out of stock when the Rotella came in.
66 Mustang (289)-Valvoline VR1 10W30
63 Galaxie 500 (390)-Chevron 10W40
99 Accord V6-Chevron-5W30
15 CR-V factory fill until MM says otherwise!
#2202043 - 03/16/11 12:47 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
mongo161 Offline
Loc: Coney Island, NY
I know that the Shell Rotella Dino 10W-30 is very difficult to find. The only places that I see it in abundance is in Farm and Horse country.
However, I just picked up 4 Gallons of the Shell Rotella Dino 10W-30 in of all places....Brooklyn, NYC.
They have a sale of the Shell Rotella Dino in 10W-30 and 15W-40. This Strauss Store location has it on sale for $12.99 a gallon and if you sign up for the rewards program them give you $5 off a purchase of $25 or more. So, after the discount and the sales tax, the total for each gallon is about $11.20.
Well, I printed out and used the coupon they e-mailed me 2X and used it yesterday for 2 Gallons and again today for 2 Gallons for my stash of 4 Gallons.
This stash won't last long....I will be using 2 Gallons of the Shell Rotella Dino 10W-30, along with a mix of the regular Formula Shell Dino for 10W-30 on a couple of SUV oil changes. Both the Shell products have great add packs and I have no problem mixing Diesel with conventional Dino.
So, if there is anyone in the NYC, NJ and PA area looking for Shell Rotella Dino in 10W-30 or 15W-40 in API-SM it can be found at Strauss Stores.
I get by with a little help from my friends....listen with your eyes....it's the ONLY way to believe what you hear...
#2205389 - 03/19/11 04:52 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: edhackett]
mongo161 Offline
Ed
+1 - Today I used 4 Gallons of Shell Rotella T Triple Protection Dino 15W-40 and 3 Gallons of Mobil Delvac Super, Dino 15W-40, all with a blend of Formula Shell Dino in 5W-20 and 5W-30. The mix for each vehicle, car and SUV was 50/50.
Both the Rotella T 15W-40 and the Mobil Delvac Super 15W-40 are rated SM for gasoline engines. I also have 6 Gallon Jugs of Shell Rotella T Triple Protection in 10W-30 in my stash that is also SM...Gasoline Engines.
#2224011 - 04/06/11 04:41 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: mongo161]
VWguy Offline
Yes Gents, thanks for all the informative feedback. I would guess that since a petroleum company has to pay large amounts of cash to get certain approvals, it probably is not profitable to get the gasoline rating on a straight weight oil that is primarily used in the HD diesel market, ie: Detroit Diesels. So, in my opinion, as long as the cam grinder says to use a certain oil, I'm gonna go by his/her recommendations. Dont seem to see any 10w-30 diesel oil antwhere in So Cal. Oh well.
#2224180 - 04/06/11 06:53 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
doitmyself Offline
Loc: MI
Geez, Bill, some of the posters here really went off topic to your original question!
I don't think we have any evidence on the make up of the new T1 30wt. vs. the old. I, too, suspect it was just a money saving move eliminating the SJ rating, but are we sure beyond just speculation? Both Kohler and Kawasaki still recommend SJ oils in their small engines.
I wrote to Shell last May because I didn't want to void the engine warranty on an expensive mower that specified 30Wt SJ. The answer was useless. He said that the T1 was suitable for gasolene use where high additive levels were wanted. BUT, then he stated that Pennzoil HD 30wt. with SM rating would also work fine. What can I say?
For peace of mind, I would buy up all the old stock. Or, use the Delo product that still has a gas rating. I base my fears on occasional "arse bites" I received not following recommendations and/or my gut. Just my opinion.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#2224228 - 04/06/11 07:37 PM Re: Difference between Rotella T and Rotella T1 30wt. [Re: VWguy]
roadrunner1 Offline
Loc: oh
After reading through this thread I went and checked my current stock of turfgard (Deere lawn equipment) 10w-30 and it is SJ.
I picked it up a couple of monthe ago, and my dealer sells quite a few mowers, I'm guessing thier stock is replenished quite often.
Anyone requirering SJ spec, its available.
'15 F350 6.7
Page 1 of 2 1 2 >
