Yes, it's got a nice TBN value, and could probably go 10k with ease. However, I think you and I are in the same boat. I also use M1 0w-30 and change it out early b/c of warranty requirements. If I'm right and you and I are alike in that regard, then continue to change it as specified by the manufacturer. However, if you don't care about the warranty, or will deal with it if anything arises, or if I'm mistaken and there is no warranty for some reason, then you can easily extend your oil change.
Don't be concerned with the "low" numbers you mentioned, overall everything looks good. Continue to use it with confidence.
