Consensus on 12 month interval oil changes
by accobra66
06/25/16 09:11 AM
Truck Wars
by AirgunSavant
06/25/16 09:06 AM
A good read....The more things change....
by ryan2022
06/25/16 08:46 AM
Opinions on linksys 1900acs router
by madRiver
06/25/16 08:18 AM
Pick my oil change
by ram_man
06/25/16 08:09 AM
Weird!
by AirgunSavant
06/25/16 08:05 AM
Good Deed?
by AirgunSavant
06/25/16 08:02 AM
Vibration after rotating tires and painting wheels
by Drew99GT
06/25/16 08:02 AM
BIBLE STUDENT GONE?
by Eddie
06/25/16 06:23 AM
Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
85 registered (accobra66, AirgunSavant, adamrc, AandPDan, 2015_PSD, 9 invisible), 1601 Guests and 13 Spiders online.
58257 Members
66 Forums
250777 Topics
#2103933 - 12/12/10 04:01 PM pressure washer - can I run W/O water
Donald Offline
Loc: Upstate NY
I need to work on my pressure washer over the winter in my basement. I'd like to start it briefly. Will no water harm it?
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2103937 - 12/12/10 04:04 PM Re: pressure washer - can I run W/O water [Re: Donald]
mikiee Offline
Loc: Missouri
I believe that water cools the pump. Will 30 secs of running harm it? Who knows. I would think you have water access in your basement. Just hook up a hose when you need to start it to be safe.
#2103945 - 12/12/10 04:18 PM Re: pressure washer - can I run W/O water [Re: mikiee]
chubbs1 Offline
Loc: Merritt Island FL, USA
+1....NOOOOO You MUST hook up hose. You will burn out the engine. I have made the mistake myself. Let me add, I don't exactly know what you mean by briefly, but no longer than 30 secs. That was the rule we all had at a pressure washing co. I worked for. My boss was forgiving eek
Edited by chubbs1 (12/12/10 04:22 PM)
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2104044 - 12/12/10 06:37 PM Re: pressure washer - can I run W/O water [Re: Donald]
SaturnIonVue Offline
Loc: New Orleans, LA
I wouldn't try it. Every brand I've ever heard of warns that running the pump without water hookup will damage the pump. Not worth the risk, no matter how short a time you run it.
`16 Elantra
`08 Saturn AURA XE, 4Cyl 2.4L - Sold
`06 Saturn VUE, 4Cyl 2.2L - Totaled!
Oil: 5W-30 Quaker State Ultimate Durability & OEM filters.
#2104821 - 12/13/10 01:50 PM Re: pressure washer - can I run W/O water [Re: Donald]
Ken2 Offline
Loc: Washington St.
Slip the belt off. You can run the engine all you want without running the dry pump. Or set up a bucket with an outlet in the bottom feeding the pump and a return into the top of the bucket from the pump...no restriction in the return so little pressure is developed. Be sure you have your will updated before running the engine in your basement. frown
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#2105193 - 12/13/10 09:22 PM Re: pressure washer - can I run W/O water [Re: Ken2]
cronk Offline
Loc: Watertown, New York
most pressure washers I have seen are direct drive...no belts.
Do not run it without water in it or you risk ruining the pump.
1998 GMC C1500
1999 Saturn SL2
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
#2105259 - 12/13/10 10:51 PM Re: pressure washer - can I run W/O water [Re: Donald]
oilboy123 Offline
Loc: Everett, Washington
Pull the pump off. Or don't run it, or you will do damage.
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
#2105710 - 12/14/10 01:33 PM Re: pressure washer - can I run W/O water [Re: Donald]
oilboy123 Offline
You could also hook up the garden hose and tie a rope to the wand handle with the nozzle on low pressure to test it. Just stick them outside and with the nozzle on low pressure it won't affect the engine much.
― Mark Twain
