Okay here is the situation guys, my nissan transaxle calls for 75w85 so i wanted to put in a synthetic gear oil and i wanted to get close to the viscosity, so i used redline mt90. I have the vq35 swap so the bellhousing from the maxima was used, and there is no gasket so nissan seal was used (didn't think of thst when switching to synthetic) now the weeping is even worse ( should of just stayed with thick conventional). OKAY to get to the point im not going to use the specified weight, i want something heavier preferably conventional off the shelf at the local auto parts store. i see alot of 75w90 but i want something thicker, but there is only heavy duty truck gear oil that would screw the trans up. what weight would you guys use thanks?
