Y'all need neighbors like this one.
by simple_gifts
1 minute 55 seconds ago
F-106 Fumoto Valve
by DBMaster
46 minutes 21 seconds ago
Propane/Oxygen vs Oxygen/acetylene
by Vern_in_IL
56 minutes 10 seconds ago
CarQuest Red 85372 Cut open
by blupupher
58 minutes 58 seconds ago
Battery dead on new car
by Leo99
Today at 05:22 PM
1997 Saturn P0326 No power
by nwjones18
Today at 04:29 PM
Can I use lower weight ?
by ST2008
Today at 04:25 PM
Amsoil 0W-30 Honda S2000 40,259 OCI w/bypass
by slalom44
Today at 03:32 PM
Holdup
by Whitewolf
Today at 03:14 PM
boosting diesel perf using propane/CNG/meth added
by columnshift
Today at 03:04 PM
HP for '96 Toyota Corolla?
by Benzadmiral
Today at 03:04 PM
Gene Wilder Dies at 83
by John_Conrad
Today at 02:52 PM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
80 registered (AnthemBassMan, 4WD, Bandito440, AlaskaMike, Astro_Guy, asiancivicmaniac, 10 invisible), 1629 Guests and 6 Spiders online.
58952 Members
66 Forums
253739 Topics
#2025210 - 09/23/10 07:53 AM Air Compressor Oil
artbuc Offline
Loc: West Chester, PA
I have a 25 year old Sears oil lubricated air compressor with a 2HP electric motor. The Owners Manual says to use 20-20W SF oil in summer and 10W oil in winter. It says do NOT use multi-viscosity oil because it "will leave carbon deposits on critical components reducing performance and compressor life". Are modern multi-weight oils ok to use? Thanks.
#2025227 - 09/23/10 08:25 AM Re: Air Compressor Oil [Re: artbuc]
Craig in Canada Offline
Loc: Toronto-ish, Canada
My 5 y/o CH compressor said similar things about most motor oils "except Mobil 1"
I chose to use an Amsoil compressor oil in the end as it's directly suited to purpose and one bottle will last me a very, very long time. You'll need to convert the SAE engine oil weight to the ISO compressor oil weight in order to select the right one. Or, of course, Amsoil could simply help you with that.
#2025234 - 09/23/10 08:35 AM Re: Air Compressor Oil [Re: artbuc]
ARCOgraphite Offline
Loc: N.H, U.S.A.
No modern multiweights still break down, shear out of grade and leave damaging deposits. What have you been using for the ppast 2 decades, seeing its 25 years old? I would think a 5w-20 oil should be safe with MUCH less VII than a 5w-30. If not use a quality SAE20 HD - if you can find one.
Edited by ARCOgraphite (09/23/10 08:37 AM)
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#2025235 - 09/23/10 08:37 AM Re: Air Compressor Oil [Re: artbuc]
440Magnum Offline
Loc: Texas
Go with a compressor oil.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2027407 - 09/25/10 01:27 PM Re: Air Compressor Oil [Re: artbuc]
01rangerxl Offline
Loc: Birmingham, AL
For most compressors you have three choices:
30 non-detergent
5W30 or 10W30 full synthetic
compressor oil
Campbell Hausfeld/Rigid recommends those oils for most of their oil lubricated pumps.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 188K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 183K miles
#2027426 - 09/25/10 01:55 PM Re: Air Compressor Oil [Re: artbuc]
JTK Offline
Loc: Buffalo, NY
Originally Posted By: artbuc
I have a 25 year old Sears oil lubricated air compressor with a 2HP electric motor. The Owners Manual says to use 20-20W SF oil in summer and 10W oil in winter...
Are you sure it's not older? That is a really odd spec for something that's only 25yrs old. I've seen the 20w20 spec on various equipment, but it was well over 30yrs old. I'd throw a 5w20 motor oil in there, especially if you need to start it cold.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2028043 - 09/26/10 06:57 AM Re: Air Compressor Oil [Re: artbuc]
Here's the thread from 2007 where I was figuring this out.
I found that Amsoil's ISO/SAE cross reference was about one grade off from everyone else's. It was determined that this was because of the properties of the syn (likely PAO) basestock they were using having a VI much better than the typical dino base for which most conversion charts are written.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=882243
If you don't want to contact someone like Amsoil and simply ask about "SAE 20W20" compressor oil you could search for a table somewhere for the median viscosity @40C of 20W20 dino and then use a table like this to map to the ISO rating.
Edited by Craig in Canada (09/26/10 06:58 AM)
#2028077 - 09/26/10 08:00 AM Re: Air Compressor Oil [Re: artbuc]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
They are basically telling you not use engine oil.
This is what you want: Amsoil ISO 46 oil (~SAE 20)
The thing people forget is that compressor oil is rated (with an ISO rating, not SAE) at 40C, not 100C as SAE motor oil is.
#2029017 - 09/27/10 08:54 AM Re: Air Compressor Oil [Re: JTK]
artbuc Offline
Joel
Joel, I can't remember exactly when I bought this unit but I am pretty sure it is in the 20-25 year range. For kicks & giggles, I will confirm the manufacturing date.
I did look at the oil over the W/E. It looks great. Can't remember when I changed it last but it has been years. I don't use it very much so I may still be well under the 100 hour OCI.
#2030992 - 09/28/10 09:34 PM Re: Air Compressor Oil [Re: artbuc]
Eastexan Offline
Loc: East Texas
Joel
My Craftsman is 22 years old (1988) and has the same oil spec as yours. I bought it about 2 years ago from a guy who had bought it used but had never ran it since he didn't have 220v hookup.
So I don't know what oil had been used in it all those years. But it was dirty and needed changed, so I called a Devilbiss (manufacturer) tech and he said it was spec'd to use the 20-20w SF, but that I could use a good syn motor oil in it. I had some 10w30 PP on hand and used that, and it's been doing fine ever since.
#2032484 - 09/30/10 08:45 AM Re: Air Compressor Oil [Re: Eastexan]
artbuc Offline
Eastexan, my Craftsman can run on 120 or 240. The wiring conversion is simple with directions right on the motor. Takes about a minute to do it.
